Question about Samsung R519-53S Notebook
When i remove my charger, the laptop turns off.
  • 734 Answers
Hi There,
This almost always means your battery is dead and you need to get a new one. I looked on eBay and couldn't find one for you. Here's their Support Phone #
Call: 1.800.726.7864
Regards,
Selk
Posted on Mar 27, 2011
    Genius:
  • 1,288 Answers
As lond as the battery is still accepting charge from the charger and will run ok on a battery, I wouldn't worry. Pulling the AC power cord isn't a good idea when the laptop is running anyway.
However, what you describe sounds like a dead battery that will no longer accept a charge. Even a battery showing 100% charged can still fail, as it drains in seconds if dead. What kills most batteries is leaving them in the laptop afetr they have charged and running on ac power.
Laptop compaq will not charge will not turn on. Puting charger on it and pushing the on button i see lights once i release on button light goes out. thinking its charger or its where i plug in charger on...
Try this quick fix, if there are no issues with your charger and/or battery, this might work...
- remove battery
- make sure charger is not connected
- long press the power button for about 1 minute
- release then connect charger or power adapter, without the battery
- press power button to turn on the laptop
If this did not help, try using other power adapter.
Nov 05, 2014 | Computers & Internet
Dell inspiron n15010
Before looking for a replacement charger, try this:
1. Remove charger from power socket
2. Remove battery
3. Hold the Power On button on the laptop about 10 seconds (while the battery is removed), and release
4. Plug in the charger to the laptop and power socket (without battery)
5. Try to turn on the laptop
Check also that all the cables from the charger are connected firmly.
If this doesn't work, you will need to replace the charger. Take the laptop with you, so you can try the new charger on the spot to be sure.
Jan 13, 2014 | Dell Computers & Internet
My laptop struck by the lightning. The power LED doesn't turn on, but the wi-fi LED turns on without power on, CPU fan starts as soon as i turn on the charger. But turning on power button has no...
Try to check if battery is removable. Remove all power source (battery and charger). Press power button for 10-20 seconds. Plug in with charger. Power on.
Sep 14, 2013 | Computers & Internet
My computer shuts down when i plug in the charger
Assuming this AC laptop charger functioned correctly at one time. Several Possibilities: (1) laptop charger has failed ... connect another compatible charger to your computer to test for this; (2) or the battery has failed ... remove battery and test if the charger plugged in directly powers the laptop.
Apr 07, 2013 | Targus APA30US AC Laptop Charger AC...
I have a problem with either the battery or my charger on my laptop compaq presario 1692. i would like to know which one of them is the problem?
Remove the battery from the laptop
Connect the charger and turn on the computer
If you have a bad battery, your computer will turn on
If you have a bad charger, your computer won't turn on
Jul 24, 2011 | Compaq Computers & Internet
My laptop wont charge when charger is plugged in it will turn on but the computer will stay at 0% battery what is the problem?
HI there, IS it a new Laptop. If yes what you can try is removing the battery and then switching it on.. Once its started just reseat the battery while its on power. You might have to try it 2-3 times if that doesnt help then your battery is broken..
Kind regards
Jul 23, 2011 | Toshiba Satellite L305-S5908 Notebook
Hp dv68x1us screen on laptop won't turn on
Remove battery and charger, when pc will be without baterry and charger, press turn on buttom , then put battery, connect charger and turn on.
May 31, 2011 | HEWLETT-PACKARD PAVILION DV6871US LAPTOP...
My ASUS Eee PC 1005P won't turn on. This had been working up until 4 days ago when I left Australia to Bali. When I pressed the power button the power light would come on but there would be no fan...
Try turning it on with the battery without the charger. Then try turning it on with the charger without the battery. If it still doesn't turn on either way, it's already a problem with the laptop's motherboard. If your laptop is still in warranty, you should have it serviced. Otherwise you need to bring it to a repair technician.
Apr 04, 2011 | ASUS Computers & Internet
I have a dell inspiron 1545. i have the charger plugged in but a red light is flashin on my laptop. this light then turns white and immediately red again.if i remove the charger the laptop just switches...
Probably battery, although that should be orange not red..
Remove battery and try it on AC alone, if that works, it was a damaged battery halting the process
If it does not, check the charger's tightness in the charging port, if sloppy or loose, this will need replacing.
Some Dell's are VERY picky about the charger, if not the exact model specified, they will not charge the battery
If none of the above, remove battery and test with another Dell charger of the same spec, if this also fails to work and you are sure the light is red, you have a problem with the motherboard. Commonly the charger power board fails on these.
Jan 06, 2011 | Dell Inspiron 1545 Notebook
Samsung R519-53S Notebook Logo
229 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
