Question about Pioneer VSX820 51 Channels Receiver
I have a pioneer vsx-820. And i am having a problem with the BD input. When turning on the bluray dvd player connected with an HDMI cable, the tv will show the start up of the dvd player, then after about 5 seconds when the dvd player attempts to show the menu page, the screen just turns green only showing a green screen. Even restarting the dvd player it will do the same thing. Restarting the receiver does not correct the problem either. I have tried connecting the dvd player strait to the tv and the screen shows everything correctly. What should i do?
4 Suggested Answers
  • 6 Answers
SOURCE: I just bought a vsx-1019ah receiver. I connected
Check if your KuroLink is on or off. There are a lot of problems that users have been having with the KuroLink on. Since you have a Pioneer display, KuroLink might help in switching both the receiver and the display on and off together, but my advice to you would be play around with the settings (in your case, especially KuroLink). Also remember, the KuroLink is on by default i.e. if you've never changed this setting, it probably is on.
Hope this solution works, else check out the Official Thread on Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Posted on Dec 07, 2009
SOURCE: pioneer VSX-818V-k wont work with PS3 or AT&T U-Verse
That model does not support audio via hdmi. That is the problem.
Posted on Feb 07, 2010
  • 15 Answers
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
Posted on May 03, 2010
Please tell me how to hook up my Wii and my cd player and my dvd player to Pioneer VSX-D309 receiver
Greetings and good health to you.
Ok, so on the back of the unit there should be labeled connections, AUX, DVD, etc. These will be your inputs.
If your Wii has RCA connectors (the plug like ends that are usually Red, White & Yellow) then you would connect the Red plug to the AUX right speaker input. The White plug to the AUX left speaker input. If you want to run the video through the unit to the TV, then you would plug the Yellow plug to the AUX video input. If not, the yellow plug with go straight to the TV. If you are using HDMI from you Wii, then you would plug that into one of your HDMI inputs.
You will do the same for CD player but using the inputs labeled CD or whatever you have available. You can use any of these inputs for any of your devices it just helps to know what is connected where.
The DVD player may be a different story. Depending on what type of connection you are using from the DVD player will depend on where you plug it in. If they are red, white and yellow...then follow as above. If they are red & white on half the cable and blue, green and red on the other, you will plug the red & white ones that are close together into the red and white audio inputs under the DVD labeled connections. Then the other 3 will go into their matching colored inputs. If the connection from the DVD player is HDMI, that will go into a HDMI slot.
Finally, connect the unit to the TV. Keep in mind that if you are using any HDMI inputs, you will need to connect the unit to the TV via a HDMI cable.
Hope that helps.
Nov 05, 2015 | Pioneer VSX-D307 Receiver
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
Can I hook my cable box into my Sharp Blu ray player
Curious why you would want to do this since both cable box and BluRay generate output signals. I doubt a single line pass-through would work since the last device on the link would override the signal with its own content when turned on.
If your TV or media system accepts multiple inputs, I would route each device to a separate input on the TV/MS and switch between them with a remote. I run HDMI lines out from both my cable box and BluRay box directly into the TV as two different lines and it works fine.
Jun 29, 2012 | Panasonic DMP-BD77 Blu-ray Disc Player -...
How to tune in for blu ray dvd
You do not tune in your Bluray player but connect using an HDMI cable or Composite cable. If you have a HDMI cable connect the Bluray's HDMI out to the TV's HDMI in at the back and using the TV's remote switch the Input source to HDMI. You will see the image from the Bluray player in high definition.
If you don not have a HDMI cable connect the composite out of the Bluray player using the Yellow/Red/White cable to the TV's composite input ( same three color sockets ) and switch to AV input on the TV. Using this connection won't give you high definition image but will work OK.
Apr 23, 2011 | Sanyo DP32746 32 in. LCD Television
No picture through Pioneer VSX 818V. Hi I have connected a blueray th the hdmi input and the tv to the hdmi, I have sound but no picture or on screen display?
Your receiver has 2 HDMI in with one HDMI out, 3 Component in and one out, and two difital optical in. If the bluray player has HDMI out this woukd be your best bet because HDMI carries the audio and video. If it has Component out, you would have to provde sound through the digital optical. Not knowing what blueray player or kind of tv you have, it's hard to advise so I may be over explaining. Anyway, we've touched on the bluray player to receiver. Out of your three HDMI slots on your receiver only one is HDMI out so make sure you're in the right one. Idaelly you have a DVD/blueray in on your receiver so on your receiver you would select "DVD" when playing. If your hook up is correct you may have to try another HDMI cable to test.
Mar 27, 2011 | Pioneer VSX-818V-K Receiver
How to hook up direct tv box,samsung hd tv,pioneer vsx-820 receiver,samsung blue ray bd-c5500
If you're using HDMI cables, which I suggest you do, this is how you set it up.
From the TV, you'll connect an HDMI cable to your receiver.
Connect the blu-ray player to your receiver.
There's a small amount of setup required with the receiver, but it's self explanatory.
Mar 12, 2011 | Pioneer Televison & Video
Recently purchased this reciever, and in reading the manual, I cannot tell if it will work if I hook my Comcast HDMI to one of the HDMI inputs (Input 2)? In general, i will be only hooking up the Cable box...
It should work fine. The Pioneer VSX 1019 AH-K has been made so that it can accept 4 HDMI inputs (of which 3 are assignable, and 1 is for the BD player)
If you still have a problem, you can resort to the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. A lot of helpful guys out there, and a very active thread.
Oct 27, 2009 | Pioneer VSX-1019AHK A/V receiver
HDMI Compatibility
It sounds to me like you have a HDMI Control issue. It sounds like the DVD player wants to control the receiver. Try turning off hdmi control on the TV, reciever, and the dvd player in their setup menus.
Let me know if this helped,
Joe
Oct 03, 2007 | Pioneer VSX-81TXV Receiver
Pioneer VSX820 51 Channels Receiver Logo
117 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
