Question about GE Washing Machines
Getting grease it tub & on clothes - GE Washing Machines
    Scholar:
  • 116 Answers
HI this is a bad transmission, the transmission costs about $200.00 to buy and you would need it installed it is a very involved job. Might be better off buying a new unit.
Sean
Posted on Mar 27, 2011
  • 552 Answers
This means the transmission has failed. Very common issue on these units. Check your use and care guide the transmission may have a five year warranty.
The job takes about two hours to complete.
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
Leaves spots on my clothes
Kathy, you may have the beginnings of a tub bearing failure. What usually happens is the water seal fails on the tub drum shaft. This lets water into the bearing cavity and usually some grease migrates out into the drum. What eventually happens is the wash water eventually washes the grease out of the bearings and they fail. You will notice your spin cycle getting louder and louder.
You can check for a loose tub bearing by lifting the drum gently at the top. Is there play where the drum can move vertically, independently of the outer assembly? That's my guess. You can do an internet search about tub bearing replacement if you want to get into that. Its doable, depending on your skill level. Good luck.
Been there and done that. Usually Frigidaire doesn't sell the bearings, but they are standard bearings and you can usually match up a seal.
Mar 17, 2014 | Frigidaire GLTR1670A Front Load Washer
2nd time I have oil stains on my clothes from Whirlpool LSR9434PQ1 and nothing gets them out. Need to know how to get the stains out and what kind of washing machine is better so that I can replace. Spent...
You can try Lestoil to get the grease out, it has surfactants that will help break up the grease, if they aren't set too deeply. This seems to me to have a leaking transmission if you are constantly getting grease on the clothes. A better machine is anything newer that you can afford, quite honestly, there is only your preference to what you want/need for your usage.
Hope this helps, please rate service and comment, Thank You,
Joe
Sep 01, 2011 | Whirlpool LSR9434PQ Top Load Washer
Maytag washer LAT9334AAM aprox 14 yrs old. Have
Are you using a liquid fabric softener ? If so , try using dryer sheets instead . Maytag is known for making liquid softener look like grease on clothes . After switching for a while , and still grease looking stains , then it is possible for the water to be getting into the transmission and pushing the grease up into the tub . Rare , but happens . Time for another machine if that happens .
May 18, 2010 | Maytag MSD2756G Side by Side Refrigerator
Grease gets on clothes from inside washer - not always but often enough to ruin several items. Also, once in a while it makes a "not normal" louder sound when spinning. We inherited this washer/dryer combo...
hello. generally this mystery grease comes from an article of clothing placed in the machine, not the machine itself. Problem is once that grease gets in the machine it can stick to the tub and contaminate other clothes in later wash loads. Look for the grease and wipe it away with a product like 409 degreaser. Regards, Joe
Jan 28, 2010 | Washing Machines
Grease-like stains on clothing
hi. i can help. the grease is coming from one of two places. Either some item with grease on it got placed in the machine and the grease transferred to the tub where it will cause the problem until it is spotted and removed with a degreaser, or wears off.
OR the grease is coming from the washer itself. Perhaps some grease oozed out of the mechanicals related to the aggitator.
Either way I would get a strong flash light or trouble light and look carefully in the tub and around the aggitator for grease. Then remove it with a cloth and some degreaser, available at any auto parts store.
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Grease on clothes
Check to see if you have movement up and down on the inner tub like a bad bearing or loud roaring noise when turning by hand if so your bearing in the back of the unit has washed its grease out and the back of the outer tub will have to be replace the bearing in factory pressed in sorry that is a hard job and not a cheep one good luck
Mar 29, 2009 | Kenmore 43142 Front Load Washer
Sometimes my clothes come out of the washing machine with splotches of fresh black grease on them.
Clean out the gunk from the fabric softener basin in the center of the machine in the tub. The gunk gets on the clothes and then gets baked in the dryer and turns out black grease.
Jul 22, 2008 | Washing Machines
Stained clothes
there no grease in ft loading washer possible cause fabric softner
Feb 03, 2008 | Kenmore 44102 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
