My Whirlpool duet 9200 is squealing during agitation, what is creating the problem?
  • Washing Mach... Master
  • 822 Answers
Could be lose belt......................
cheers
Posted on Mar 27, 2011
  • mjccpa Mar 27, 2011
    naw, its the motor.
What causes this machine to squeal while running?
I had a similar issue, had a bad bearing. A quite frequent failure int this device. Only way to diagnose is dismounting it
These are not properly your model but see some videos how to do it:; might help to understand the job
How to Replace Washing Machine Bearings
Repair HE3 Washing Machine Bearing Noise
ApplianceRepairVBlog 2 Replacing the rear bearing on Whirlpool Duet...
Duet Whirlpool Sport Changing Bearings
Aug 02, 2015 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool duet ht will not agitate or spin
Front load washers don't "agitate". Did you mean it doesn't tumble during the wash cycle? I need more information. Complete model # and a more detailed description of the issue.
Mar 16, 2014 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 06, 2010 | Whirlpool Dryers
Whirlpool Duet washer
Many Whirlpool built 'direct drive' washers (including Kenmore, KitchenAid, Roper, and Inglis) use a 2 piece agitator. There are cogs called 'dogs' or 'dog ears' and a cam between the two halves of the agitator which can wear leading to a clicking/ticking sound and reduced movement of the top agitator section during the wash cycle leading to poor cleaning results. In most cases these worn parts can be replaced without much cost or difficulty.
The top section of the two piece agitator is usually removed by first pulling off the agitator cap then removing the inner cap. Underneath those there is usually a 7/16" bolt which will need to be unscrewed. Once removed, the top agitator half can usually be pulled straight up to access the defective components.
The clutch cam and clutch dogs usually responsible for problems should be found in the now removed upper portion of the agitator assembly.
Although just the agitator dogs are available separately, a worn cam will eventually result in the same failure again. All worn components should be replaced together to reduce the chance of the condition recurring.
http://www.american-appliance.com/old_Site/service_pages/wp_dd_wash/dddogreplacement.htm
Check the above links to know how it is to be replaced..
Apr 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Feb 16, 2010 | Washing Machines
Whirlpool Duet Front Loading Washer Model GHW 9200 LW
what shoul I need to fix when the light sensing on and the dryer does not start ( it still hot ) .
Whirlpool dryer GEW9200LW
reply to tomagic3@yahoo.com
thanks
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
