Question about Motorola Mobility RAZR V3
How do i change the time format from 17:39 to 5:40
  • lredgrl55 Mar 27, 2011
    Please work me through it step by step
    where is that on keypad?
  • 902 Answers
Under date and time settings you can change it from military time to standard time
Posted on Mar 27, 2011
  • 2 more comments
  • brian shevack Mar 27, 2011
    I think it will be called time format
    where do i find that on keypad?
    Forgive me i have not had a razor in years. I know you must first go to menu and its either under settings or applications then you will find your time and date options
    i think its menu-settings-initial settings/setup-time and date
Get off Military time
  1. In your computer, go to "Windows Help and Support".or go to step 4.
  2. Search for "clock time format"
  3. Select "Change the display of dates, times, currency or measurements"
  4. Click to open "Region and Language"
  5. Select "Additional Settings"
  6. Select the TAB named "Time"
  7. Where short time and long time are formatted change short time to: h:mm tt and the long time to h:mm:ss tt (note: the h is lower case for 12hr and uppercase for 24)
  8. Click apply after you change the time format and close open windows.
  9. You're done!
Aug 29, 2015 | Acer Computers & Internet
How do I change the email received day/time format to time/day/month/year format on MS OutLook
Hi George,
You just need to set the correct time zone from Control Panel.
For XP: Just double click the time from your system tray, click on Timezone tab then choose your timezone from the drop down menu then click OK.
For Vista/7: Click on the time from system tray, click on "Change date and time settings". A window will pop up, click on "Change time zone" button, choose your timezone then click OK.
Hope this helps.
Charvin
Nov 21, 2012 | Microsoft Office Outlook 2007: Windows
How do I change the time on the clock?
  1. Tap Menu > Settings > Phone
  2. Tap Time & Date.
  3. Tap Time Format, Date Format or Auto Update > Save
It's best to keep it set to Auto Update so that it takes the network time and updates for DST changes.
Hope this helps. If so, please consider rating this solution.
-best regards,
M
Mar 14, 2011 | Pantech Pursuit P9020
How do you change the time
On most phones that I've ever seen, you can't change the time. It's set by the provider and will automatically update. You may be able to change time zones though...
Mar 13, 2011 | Pantech P2020 Ease Crystal Screen...
Hello, so, this is the situation: I have lost my TV manual and I want to set the TV picture format to 16:9 for permanent, or even better, set it to "automatic". I have the Sony RM-833 remote...
Your TV's native format is 4:3 so to prevent burn in effect the TV will go back to 4:3 every time you turn it off or change channels.
Mar 07, 2011 | Televison & Video
MY DESKTOP TIME IS IN 24 HR FORMAT
START->CONTROL PANEL->DATE,TIME,LANGUAGE.....->Change format of numbers,dates and time. Under regional and language option click customize option and select time tab under customize regional options . There would be an option to change date, time change format. Click that and it would fix the issue.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 02, 2009 | Computers & Internet
Changing time format
go to control panel > regional setting, at time tab, you can change time format from H:mm:ss to h:mm:ss tt
Jun 11, 2009 | HTC Touch Diamond Smartphone
Set the time and date on a canon mp25dv/instructions
To set date:
1. Press the calendar/clock button (display should show date)
2. Press and hold the 'time set' button for 3 seconds (first digit of the date should flash)
3. Use the numeric keys to enter date using mmddyyyy format
4. Press 'time set' button
To set time:
1. Press the calendar/clock button twice (display should show time)
2. Press and hold the 'time set' button for 3 seconds (first digit of the time should flash)
3. Use the numeric keys to enter time using hhmm format, press 'AM/PM' button as needed
The '12/24' button changes between 12 hour and 24 hour format for time.
The 'format' button changes the date format from mmddyyyy to ddmmyyyy or yyyymmdd.
Feb 26, 2009 | Canon MP-25DV Calculator
Xerox workcentre Pro 575 How do I change the time of day setting
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [4], [2]. The screen will display: Date.
    [01-31-2000]
  2. Use the numeric keypad to enter the date and the arrow buttons to move between the fields, then press [Enter]. The screen will display:Date format.
    1. MM-DD-YYYY
    2. DD-MM-YYYY
    3. YYYY-MM-DD
  3. Use the numeric keypad to designate the Date format you require to use. The screen will display: Month format.
    1. Numeric: displays the month with a number
    2. Name: displays an abbreviated month name.
  4. Use the numeric keypad to designate the Month format you require to use. The screen will display: Time format?
    1. 24 hour
    2. 12 hour
  5. Use the numeric keypad to designate the time format you require to use. The screen will display: Time.
    10:30 pm (or 22:30 pm if you chose the 24 hour format).
  6. Use the numeric keypad to enter the time and the arrow buttons to select [AM] or [PM], then press [Enter].
  7. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
Nov 20, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
How to change the date format?
Select the cell or column or range containing the date(s). Click Format -> Cells On the Number tab, click Date This will give you the various formats available. The default date format is determined by the settings in the control panel. Windos XP: Control Panerl -> Date, Time, Language and Regional Options -> Change the format of numbers, dates, and times -> Customize This dialog box has tabs for Numbers, Currency, Time, and Date. There you can select the default formats for how you want things to appear. Hope this helps.
Sep 08, 2007 | Microsoft Office Standard for PC
Motorola Mobility RAZR V3 Logo
94 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
