Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My compressor keeps clicking on & off, and isn't cooling any longer
  • 5,370 Answers
There is a start-up capacitor beside the compressor.When this capacitor fails, the compressor keeps clicking on /off.The capacitor is not very expensive.It costs near to $25.But if replacing the capacitor is not helping, then its faulty compressor causing this.The compressor is out of refrigerant gas and its getting short internally.You will have to get the compressor replaced.If replacing the capacitor not helped.The parts like startup capacitor and compressor can be bought from online sites like repairclinic.com or from sears parts direct site.----------- This will help.Thanks.Helpmech.
Posted on Mar 27, 2011
  • Whirlpool Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
First off... unplug the unit for 30 minutes and let the compressor / coolant system stabilize and cool. Then plug it in and see if the unit starts.
Things that cause this symptom:
1. Momentary power loss
2. Compressor PTC relay failure
3. KliXon thermal overload failure (yours is working i.e clicking)
3. Run capacitor failure
4. Locked Compressor Rotor / 1 of 2 windings open in the compressor / bearing failure of the compressor. (Any of these require compressor replacement)
Without your complete model number I can not pass you replacement parts sources.
The repair process will be (even if done by a tech):
1. Compressor winding to compressor case resistance test. Resistance checks from terminals C to S, C to R and terminals [C, R and S to ground / chassis ( 2. PTC Relay / thermal over load replacement
3. Run capacitor replacement
4. Locked Rotor Amperage Test (checks amperage to see if the amps being used is equal to the LRA value on the compressor label.
5. Compressor replacement if none of the above resolve the issue.
Usually the PTC, thermal overload, and run capacitor are all replaced at the same time. (Can be up to $100.00 in parts depending upon model but this a must do process with your symptom.)
If you require further assistance I must have your model number when you respond here.
Thanks for choosing FixYa,
Kelly
2 Suggested Answers
tborn6
  • 700 Answers
SOURCE: FAN WORKS, BUT FRIDGE AND FREEZER NOT COOLING,COMPRESSOR KEEPS CLICKING ON AND OFF
sound like the start components are weak on the unit. you can get new start components or get a three n one control that repalces the starting components and all that you have to do is wire it up just like the diagram on the bag. or the lem could be low voltage gpoing to the refriger ator. The manufactures reccommend that you never run a refrigerator on a extenstion cord of any kind. It is also a good Idea to take the refrigerator electrical outlet off of any type of GFI receptical of any kind. you don't want to come home to a defrosted mess just because the outlet decided at that Tibme to trip.
Posted on Jan 01, 2009
My refirgerator model number pbf2255hew stop cooling & compressor stop working...tries to come on but won't
Check your fan on the back of refrigerator...Might need replacing..Surly needs cleaning
Dec 08, 2017 | Maytag Refrigerators
Coleman compressor runs no cool
Sounds like a blockage, which isn't permanent and let the unit cool the other day. Reclaim the gas, cut the capillary at the drier end and blow nitrogen through. Rebraze the capillary, vacuum and put new gas in.
May 15, 2012 | Coleman 13.5K MACH 3-WHITE
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
Refrigerator isn't getting cold anymore
Check if the compressor is running. If not, test for power to the compressor. If the compressor feels very hot, and you hear something clicking, then you probably need a new starting relay which is inside a little box on the side of the compressor. You might have to wait several minutes for the compressor to cool off before it will do its next "click-on" and "click-off" thing. If the compressor is cool, and there is power going to the relay, the overload (next to the relay) could be "open" (no continuity).
Sep 07, 2011 | Beverage-Air CT96Y1B (6.8 cu. ft.)...
Maytag MDS2351- came home one day and noticed water coming from where u get the ice and water when i opened the freezer it was not cool and everything i had in there was defrosted and then when i went to...
Your fridge operates like that: a compressor liquefies freon vapours; this creates heat so the hot liquid goes thru a cooling radiator with a fan on it (these 2 elements are at the rear bottom of the fridge) the freon fluid goes to an evaporator, turns to vapour and absorbs heat in the process, cooling the evaporator; a fan blows air over the evaporator and spreads the cooled air all over the fridge; the vapours return to the compressor.
In the rear of the fridge you should make sure that the radiator is clean and the fan working; inside the fridge you should make sure that the evaporator is not covered in ice and/or dirt and its fan is working. If necessary clean both.
If they are clean , the fans work but the evaporator isn't cold then either the freon circuit has sprung a leak and all the fluid has been lost or the compressor isn't working - to find out which just put your hands on the compressor : if it's hot and vibrates the fluid has been lost, if it doesn't vibrates then the compressor isn't working.
The compressor isn't working because either the thermostat or itself have failed. To find out which the compressor will have to be powered directly from the mains: if it starts then the thermostat must be replaced, if it doesn't the compressor will.
To fix the freon circuit or to replace the compressor a certified professional is mandatory, you must call one.
Jul 12, 2011 | Refrigerators
I've had my air conditioner for a few years now and it no longer cools anything. The fan works, the condenser(?) turns on when I set it to cool instead of fan, but the air coming out of it isn't...
You need to determine if the compressor is running, if it is and you have no cooling then you either have lost charge or bad compressor, these units re not worth replacement compressor
Jun 22, 2011 | Goldstar R5208 Air Conditioner
Refrigerator installed under counter and stopped cooling
possible bad compressor. check amp draw of compressor. tech info is usally on model # tag on amps. If amps close to recommendation you could need a start kit but more than likly a compressor .
Mar 05, 2010 | Refrigerators
While using a little longer than usual the
small compresers all seem not to be able to do a lot of work in one time.it seise's then free's up again when cooled down.
Dec 30, 2009 | Seth Thomas Thomas T 635HT Renegade Air...
Skybox
Check the compressor to see if it is running. Is it too hot to touch. If so make sure the condensor has proper air circulation to cool it. If the compressor is cool to touch and running. There is a leak in the refrigerant sealed system.The compressor isn`t doing any work because there isn`t any refrigerant in it, therefore will not creat much heat. A humming and clicking sound is typical of an overheated or damaged compressor. If the compressor isn`t running and connot start. It could be a bad start relay on the side of the compressor or a bad compressor. If you can remove the start relay, shake it and listen for a rattle sound. If it rattles, it is bad.If not. then it is time consider the cost of a repairman verses the value of the appliance. Check the cost of repair to the sealed system or maybe even replacing the compressor.I hope I have been of some help to you.
Nov 12, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag refrigerator clicking
it sounds like a bad:
  • ·       start switch (on the side of the compressor) or
  • ·        compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Jul 06, 2008 | Maytag 23 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
785 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
