I have a Bosch series 100 washing machine. It will not spin. You can hear a clicking noise, but there is no tub movement. The drain appears to be clear.
  • Washing Mach... Master
  • 822 Answers
If the machine washes then its the pump..............
cheers
Posted on Mar 27, 2011
How to replace a drain motor on a bosch nexxt 100 series washer
Maybe you just need to change the motor brushes. YouTube has some great videos. Spares here on Fixya. Did you check out your filter?
Click if helped.
Mar 18, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
RE. Bosch Nexxt 100 series. Does not spin. I have cleaned all hoses, outflow and inflow. Opened the little circle door at bottom right and it is clear. The fan even spins during drain cycle. I do hear...
Check connectors on motor assembly they can become loose due to the high speed and vibration. Motor and drum are tied together. I had similiar problem with mine after spending a few hundred on a control board which made no difference.
Oct 12, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a 2009 bosch 100 series washer that won't wash or spin, but will drain?
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Mar 06, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 800 series. We have continued problems with the message "suds or blocked pump" we use HE detergent.. what else?  I have drained it once.. it seems that it continues to not pump out the...
Hello,let the machine rest for a while so suds can disappear then unplug the unit for 1 min then plug it back in it should drain by its self if not do not select wash cycle but a spin/drain then you should hear the pump running, if you don't hear the pump running you can get a wet/dry vac stick on the drain hose and empty the washer, that way if water does not come out you have to access the pump and pinch off the drain hose from the tub and remove the object from the pump, be careful that you don't have a mess with water leaking from the tub good luck.
Thanks
Jun 03, 2010 | Bosch Nexxt 800 WFMC8401UC
Why won't the washer drain? Pump appears to be
if this issue is because you hear water in the machine when the tub spins......
thats normal, its called the balance ring
centrifical force, pushes the water in the lid, outward helping to use the sling weight, as a counter balance
its 100 percent normal to hear sloshing when turning the tub by hand
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine does not spin
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
It will not agitate or spin.
needs new bushes to electric motor common fault when the bushes wear down it cuts power to machine this will stop washer from washing and spinning
Jan 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
