Question about Sharp VL-E600U 8mm Analog Camcorder
I can't open the tape compartmen of my Sharp camcorder (VL-E60U). Does it work only when batteries are charged?
silly girl
  • 513 Answers
SOURCE: Camcorder Error
Seen this error maybe a 100 times, nobody knows why it comes up or what does it mean. I suggest you go get a special alcohol to clean video heads, and swab at the head a few times. If it does no good, perhaps get on the phone with sharp and tell them there are plenty of people interested to know what exactly e007 means. Please post on any developments.
Posted on Jun 08, 2006
Benimur
  • 6966 Answers
SOURCE: downloading footage from USB camcorder to a MAC
Hi, still pictures being in digital format would be downloadable to the computer straight from the camera. Video footages in tape is analog and cannot be dowloaded. You would need a video capture device. It is an interface device that sits between your tape player/camera and your computer. Normally would have a video input either in RCA (yellow) or S connector and provision to connector to your computer (USB, firewire). Also provision for audio (white/red) connection or straight to the line/aux input of your computer. You then have to run the accompanying software to capture the movie while it is playing in realtime in the camera. If the video footages are saved in a memory stick, flashcard or some other digital format, then it is directly readable/downloadable from the camera to your computer. Hope this be of some help. Regards.
Posted on Apr 25, 2007
SOURCE: Driver for Sharp VL-Z5 Mini DV Digital Camcorder
Try this
http://www.sharpusa.com/products/TypeSoftware/0,1086,47,00.html
Posted on Jun 28, 2008
SOURCE: Sharp Viewcam VL-E66U
I let it sit overnight and when I opened the door I nudged the part that holds the tape up. I got the tape out but I think it is still frozen. I will try a different tape and hope it still works. I'll post results.
Thanks
Kate
Posted on Sep 08, 2008
mediarich
  • 188 Answers
SOURCE: Hooking up T.V. to my camcorder
Does your TV have an input which would be lited as Video 1?
There should be video and audio outputs from the camcorder and if you have video and audio inputs to your TV you just need a cable and the capability to view it on your TV. If you don't have audio and video inputs to your TV you should check out the sales at the local electronics store. I hope this helps.
Posted on Dec 12, 2008
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and...
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and I've also tried it with power supply connected?
Oct 04, 2011 | Sharp VL-Z5 Mini DV Digital Camcorder
Hello. I used to own a SHARP VIEWCAM Camcorder (model# VL-E650U). I lent it to someone & never received back. I would like to know if there is any other product/device that I can use to play/view the...
Want to buy my VL-E650U Sharp Viewcam? Selling bag, camcorder, 3 tapes, manual, remote, and two batteries. Although the batteries don't hold juice very long any more, all the other items are in great shape without blemishes. Liz
Jun 17, 2011 | Sharp VL-E650U 8mm Analog Camcorder
Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
Oct 18, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Cancorder not wrking-e007 error message
moisture in the cassette holder. Take out the cassette, leave the holder door open for a couple of hours in a dry, warm location, and it should work again.
Sep 12, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Camcorder gone bad
First a few questions:
1) Will the unit accept a tape or is it completely dead?
2) In camera mode, does the viewfinder work?
Thanks,
Dan
Feb 17, 2009 | Sharp VL-A45 8mm Analog Camcorder
Thanks
Kate
Sep 07, 2008 | Sharp Viewcam VL-AH151U Camcorder
Sharp Hi8 Video Camera VL H410
This camera needs to have the battery recharged in order to remove the tape.
Apr 14, 2008 | Sharp VL-AH131 Camcorder
Sharp Camcorder VL-NZ100E battery doesn't seem to charge
2.7 volts is too low. Usually camcorders use battery at least 6 volts. Problems with rechargeables especially NiCds and NiMH, a cell will be shorted. for 6 volts pack, there are 5 cells in series (5 pcs x 1.2 volts with load , 1.35 no load). If you are measuring only 2.7 volts, it is highly possible that 3 cells are dead. As for the charger, if the same charger is used to power the camcorder and you said the the camcorder operates using the adaptor, this means that the charger is OK. You can ZAP the battery back to life but I will not recommend. It can be dangerous. If you can buy the battery, I suggest you do it since the old battery, even when zapped, will not provide enough juice anymore.
May 22, 2007 | Sharp Viewcam VL-NZ100U Mini DV Digital...
Video Cameras Logo
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
