Question about Zebra LP 2844 Thermal Printer
The zebra designer software doesn't start. I double click on it, the logo apears and then nothing. I can't open my saved labels nor print them.
  • 902 Answers
What os are you using?
Posted on Mar 27, 2011
Label created with Zebra Bar One V5 read in Zebra Designer
Hi Jonathan. Did you ever reach a solution? We are in same baot with over 60 Barone v5 formats to convert to SAP. Thanks in advance. Mike
Jul 04, 2012 | Zebra DESIGNER FOR MySAP BUSINESS SUITE V2
Dear Sir, Madam, We recently installed our Zebra S600 labelprinter together with the Zebra Designer software. But the labelprinter doesn't print out our labels. We've searched the internet and...
It sounds as though it is printing test labels. Switch of and on again to reset.
If no change then try factory reset.
If it is ever necessary to return the printer configuration to factory default values, press the FEED
key and PAUSE Key at the same time while turning the power on. The default values will remain
active until the printer power is turned off. To save the default values in memory, press the MODE
key four times. The Darken, Position, and Calibrate LEDs will cycle on and then off indicating the
values have been saved.
If this does not work then you have a fualty logic board which write off the printer
Jul 06, 2011 | Zebra Stripe S600 Thermal Label Printer
I've got some problems with my zebra zm400 printer. It says error ribbin out
The default setting is thermal transfer for this printer. You can change the setting on the printer so it doesn't show you the error any more by doing the following: Press SETUP/EXIT Press Plus (+) to scroll through the different parameters About the 6th parameter is "PRINT METHOD" Press "SELECT" to select the parameter Press Plus (+) or Minus (-) to change to Direct Thermal (no ribbon) Press "NEXT/SAVE" to save your changes If you make the changes to you printer and as soon as it prints it reverts back to thermal transfer, then your label software or your driver are overriding it and you need to make the change there.
Changing the setting in your label software - this will also change the settings for this label only Open your label Make the change under "label setup" or "page setup" inside your label software.
Changing the setting on the driver - this will also change the default settings for all future labels that you create Go to control panel and devices and printers. Locate the driver for your label printer and make the change under "Printing Preferences".
May 05, 2011 | Zebra 203DPI Printer
Just one of the double tags is printed on
I assume by double tags you mean 2 labels across the roll.
You need to tell your software that the roll is 2 across.
If using the software that comes with the printer, Zebra designer.
Set your label width to twice the single label and copy the barcode so that you have 2 across the label, then print
Feb 10, 2010 | Zebra Eltron TLP 2844 Thermal Label...
How do you clear the printer buffer on a zebra 140Xi111 plus
1. click on "start" select "run" and type "services.msc"
2. after open services windows select "print spooler" services
3. stop "print spooler" services
4. click on "start" select "run" and type "C:\WINDOWS\system32\spool\printers"
5. after open the printers folder deleted all the pending print jobs
6. restart the "print spooler" services and try to print now.
Aug 06, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Apr 21, 2009 | Zebra Z4Mplus Label Printer
Zebra TLP 2844-Z Test page print within Win XP
This printer requires special software to print labels with. It uses a unique PCL language to work with. Thats why when you use these printers with Fedex or UPS software, it typically downloads forms first before working.
Zebra used to see a label designer program to work with it. You might want to check with them to see if they still carry it.
Jul 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2742
In www.zebra.com ZebraDesigner can download the software to design and print labels.
Jul 22, 2008 | Zebra Eltron TLP 2742 Thermal Label...
Zebra 4M Plus
What software are using? If you use or Zebra Designer Label Matrix, uses its own drivers. If you use another driver, verify that the graphics option is "dithering".
Roberto Martinez
May 20, 2008 | Zebra Z4M Printer
Zebra LP 2844 Thermal Printer Logo
118 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
