Hi, it's Allie from Crucial Vacuum!
Changing your belt is crucial in keeping your unit running efficiently. It is recommended for belts to be replaced every 6 months.
To get access to your unit's belt, your floor base should have two plastic screws that will allow you to remove the roller brush casing. After removing the casing, you will be able to see your roller brush, now it's a good chance to, with a pair of scissors, cut any tangled hair strands or left over debris that is tangled in your roller brush. There are also four more screws that need to be removed to get access to the belt and the clutch assembly.
The roller brush clips in onto the floor base with one clip on each side, you can gently but easily unclip it. Remove the cover on top of the belt and the bearings with a screwdriver, remove the bearing end caps to reveal your unit's belt to be replaced.
You can purchase direct your replacement bags and filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=S7260
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
