Question about Gateway Profile® 6C (PROFILE6C) PC Desktop
SHUTDOWN ALL OF A SUDDEN WHEN I'M CHEKING MY EMAIL, I TURN IT ON, STAYS ON, CAN'T BOOT, INSERTED OS TO FIX IT BUT JUST SPIN AND STOP, POWER STAYS ON AND FANS ARE NOT MOVING, BLINKING LIGHT IN MOTHERBOARD, CAN'T DO ANY THING CAN'T SETUP BIOS IT STAY ON AND NO RESPONSE. ONLY THE BLUE LIGHT FROM START BUTTON AND BLUE RED LED LIGHT UNDER IT. I ALREADY REMOVED AND REPLACED ALL CABLES AND HARDWARE, AND SAME PROBLEM ACCURS. THANK YOU
    Problem Solver:
  • 5 Answers
What hardware have you replaced? do you hear a beeping sound? try removing everything (HDD, DVD/CD/FLOPPY/)except the proc,video card and mem on the motherboard and try to boot. check if it will give you bios. if it still the same, do an isolation test. the main reason why its not responding is your computer doesnt complete POST. POST is one of the process the computer do to test all the hardware that is connected on the motherboard, if one fails and POST doesnt complete, you wont see the BIOS startup screen. Theres a lot of possible fault on this concern. since theres a lot of things connected on the motherboard
Posted on Mar 27, 2011
Why does the blue light stays on but it won't turn on or off
Your pc may be set to stsndby or sleep mode instead of shutdown. Have a look at control pamel, power settings and change to shutdown when turning off.
Sep 05, 2014 | Acer C720 Chromebook Gray 11.6" Notebook...
My sony vaio turns on the vaio sign flashes up, then nothing else happens. It sounds like its doing something but stays on greyish screen, no cursor shows. Then all off a sudden it justs restarts itse
Sounds like your having issues with your OS (windows or equivalent). This could be cause by virus/malware not being "treated" or with a critical update install failure. Do you have your OS original CD? Go into Enter Setup when the HP logo comes up by pressing the F function button it shows at the bottom of the screen under the HP logo. Look for Boot Options and make sure that your OS CD or bootable USB is the first one in the boot list. Save and exit. It will boot from your external drive (CD/USB key) and will you the option Repair. Try that and let me know!
Feb 02, 2014 | Sony VAIO Computers & Internet
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
How to fix acer d255e blank screen
If ur OS dont boot u must chenge ur windows
If ur windows is boot u can install driver for vga output
Oct 31, 2017 | Acer Aspire One D255E13438 Netbook
Boot up problems for HP Compaq nx7300?
The main problem I assume from what you are reporting is the computer is powered up. but will not boot? Forget the Battery, lets look at the boot process. Considering that the computer has power, the CPU is sending instructions to the hard drive, Please Boot and Start Up. If the Hard drive is defective, it will not obey any instructions to start because the Boot Feature is not operative. Most likely the problem. Remove the hard drive and replace it with a new drive. The new drive is partitioned and ready for the operating system to be applied. You will need a new updated OS (Operating System Win 10) to boot and add programs. Replacing a hard drive is easy. Open the case, locate the hard drive, disconnect it, remove, and look at the details printed on the drive. Usually a SATA drive. You can purchase a new drive on Amazon for $30. This is dependent on the capacity, the 1Gig are about $40. In reverse, put the new drive in the old drives slot, hook up the wires like they were with the previous drive, and with the new Operating System disc inserted into the CD/DVD drive, turn on the computer. The CD/DVD should spin and on the monitor, show the start up for the Installation of the software. It asks for the licensed Key from the OS container. Just go from there. When complete, the new hard drive will be formatted and contain the WIN OS. Now you can boot the computer and add new programs. As for the old drive, if it was dead, you may have lost all data. Always do a back up along the way to preserve valuable data. Using USB Sticks is a good method.
Feb 07, 2018 | HP Compaq nx7300 Notebook
Power light flashes on and off but will not turn on. Dell Lattitude c600. Was working then all of a sudden now won't start. Tried reseating RAM and HDD but to no avail. Any ideas
Try this quick fix: Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot. Then shutdown your computer and put the battery pack back in.
If that doesn't work, it could most likely be the cause of electrical shorts. Check to make sure that there are no frayed wires or cables inside your computer, and if any are found, replace them.
Electrical shorts can also be caused by something, like screws, coming in contact with the motherboard or other hardware. Pick up your computer case and really gently shake it side to side. A screw may have come loose in the case and is rolling around in it, so you will hear a rattling sound if that's the case. A few light shakes will usually knock it loose and onto the bottom of the case.
Your computer's power supply may have failed. Test your power supply for failure (use a multimeter or power supply tester if you know how to). Or take it to your local PC Repair shop to get it tested. Do not try to fix a power supply yourself without experience- it is highly dangerous. For instructions on how to use a multimeter, contact me (email address at bottom of message).
Hope this helps!
Email me if you have any other problems, or need more help with this problem at g33kg1rl7@gmail.com.
Feb 12, 2010 | Dell Latitude D600 Notebook
Toshiba - Satellite A75-S1253 STOP: c000021a {Fatal System Error} The Windows Logon Process system process terminated unexpectedly with a status of 0xc0000034 (0x00000000 0x0000000) The system has been...
you have to reload the operating system.get our xp or what ever os your running and boot off the cd.if you have any questions or need help with reloading the os,and data recovery please email me at gamecrazy944@yahoo.com
Jul 16, 2009 | Computers & Internet
System won't complete the RESTART process
Do a check disk (chkdsk) using either:
1) Go to My Computer > right click on the drive with windows that won't boot > click properties > go to tools tab > click error checking > tick both boxes and click check now > it will say windows needs to restart, allow it too.
OR
2) Boot up using the installation disk... I will need the OS version (XP, Vista etc.) to tell you how to do that.
May 08, 2009 | Soltek SL-K8M800I-RL Motherboard
Can't install Mac OS X Leopard on Power Mac G5.
email me at glenn@light.on.ca i have the fix for you
Nov 20, 2008 | Apple Power Mac G5 Desktop
No boot or bios or display at turn on.
I had exactly the same problem with my kids PC last week, also an Asus on an AMD flatform. I reset the BIOS and clean install the OS and now its working fine. You have to reformat the harddisk, cause in my case it doesn't show its exact capacity when I it hooked it up as slave drive with my own PC. Maybe a virus did it.
Apr 07, 2008 | ASUS P4C800 Deluxe Motherboard
Gateway Profile® 6C (PROFILE6C) PC Desktop Logo
81 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
