Question about HP Compaq Evo n610c Notebook
Notebook is not powering up
Hello my power code was loose and would slip out of the socket occasionally and now the batter wont work and I am unable to power up the lab top. I purchased a new battery but that did not get it to power up. So at this point I have a dead notebook on my hands.
  • 3,940 Answers
You have a fairly common failure of teh power plug on the motherboard. You can get a replacement for less than $100and have it installed locally for about the same price if you are not comfortable doing it yourself.
Motherboards are available here:
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=evo+n610c+motherboard&category0=
Posted on Aug 04, 2008
Asus eee pc 1000ha wont take charge from adapter
try unplugging from the mains, remove the battery, hold the power button down for 30 seconds. plug the mains adapter in and try turning on. if it doesn't work then it's either the power socket or the mainboard.
if it does work, then try it again with the batter in. if it stops working then your battery's shot.
Apr 13, 2013 | ASUS Eee PC 1000HA Notebook
My new battery is not working with my Sony vaio laptop
What do you mean the new batter is not working? Does the computer turn on with the Power Cord? If not, the power cord is bad and cannot charge the battery. I have seen times when new batteries are defective. The new battery does not come charged so you have to plug in the power cord and let it charge overnight.
Apr 06, 2012 | Sony Computers & Internet
Wont turn on
Hello.
The most common reasons are your batter and power adapter.
Disconnect all cables, flip the laptop, unlock and remove the battery. Reinsert and lock, connect the power adapter and try again.
If still a problem, disconnect all cables, flip the laptop, unlock and remove the battery. Connect the power adapter again. If it works, your battery is faulty and needs replacement. if it doesn't work and there is no light on the adapter, your adapter is probably faulty.
Also, try this: wiggle the power adapter where it connects to the laptop. If the power goes on and off, the power jack is faulty and needs soldering or replacement. Leave that job to an experienced tech.
Hope this helps.
Dec 02, 2010 | Dell Latitude D600 Notebook
Battery not charging !!!. replacement of new batter also has the same problem. and old batter suddenly started charging by meddling with the cable for once. and then again the same problem. would it be...
Looks like either the power jack of your adapter is experiencing a bad connection. Check if the power adapter's cable near the jack which plugs into the laptop is not severely bent.If this is the case, then you will need to replace the power adapter.
If this is not the case, check the DC socket where you plug the power jack into the laptop. This socket might be loose or broken. If this turns out to be the case, then your laptop needs to be disassembled in order to re-solder or replace this socket, depending on its condition.
Aug 28, 2010 | Dell XPS M1530 Notebook
My laptop wont even turn on! how do i make it work?
OK! I'LL PLAY ALONG?
MAKE SURE POWER CABLE CONNECTED TO REAR OF LAPTOP/PLUG END IN SOCKET/TURN ON SOCKET/MAKE SURE POWER AT SOCKET?
OPEN LAPTOP/SHOULD SEE LED(S) SHOWING?
LOCATE SWITC/BUTTON/PRESS/SHOULD HEAR HDD STARTUP AND SCREEN ACTIVATE?
BATTERY MAKE NEED RENEWING IF NOT HOLDING CHARGE?
Nov 15, 2009 | Compaq Presario Notebook
Hello heres my problem the power cord tip gets so hot and burns even ive replaced the battery ive replaced the cord and the tip and its stil happening help please
Seems that your notebook's power socket, where you plug the power cord, is damaged & is causing a loose connection. The loose connection causes the power socket as well as the power cord's tip to overheat & burn.
Oct 30, 2009 | Compaq Presario M2000 Notebook
My Samsung R40 will not charge. The cable/charger
it is called the AC power Wall Socket is that what u r talking about do u think u can replace it i think u should call some elec guy to fix it like maintenance guy it has nothing to do with ur notebook its just the pins inside the socket got loose and ur plug is unable to stand in there am i right pls vote if u find me helpful
Feb 22, 2009 | Samsung Computers & Internet
[[ACER WONT TURN ON]]
You might of fried the whole motherboard when it sparked. Check if there is a fuse. Bridge the gap, and it should turn on. If not PULL THE PLUG.its something else that went wrong.If you don't, it smells really bad. Ive learn't from experience...
Jul 28, 2008 | Acer TravelMate 2300 Notebook
R50e PC Notebook Problem
And once you get the power socket (pin) repaired, get a Cable Retention Device like the video shows. . .
Dec 09, 2007 | IBM ThinkPad R50e Notebook
HP Compaq Evo n610c Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
