Problem with mu copier
When i turn my copier on, it flashes 0000 and then an E. What shall i do inorder to fix this problem??
    Sniper:
  • 54 Answers
You can not mention the machine model & company
Posted on Aug 14, 2008
Canon copier error e000007-0000 canon 2420 image burner
Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film sensor. - Replace the fixing film sensor. - Replace the DC controller PCB.
Mar 10, 2015 | Canon Office Equipment & Supplies
Need pairing code
By defaul code should be 0000 or 1234
Feb 19, 2014 | Brother MFC-790CW Multifunction Printer
E000007-0000
This is not a problem for the IR-5000 copier. This is an error code for the instant on copier that use a fixing film assembly. This is error indicating that the fixing film isn't turning in the fuser assembly and most likely is damaged and the fixing film assembly will have to be replaced.
Aug 15, 2012 | Canon imageRUNNER 5000 Copier
How to reprogram nokia 6151?
hi,
you can fix that by using this gadget , tools and flash files
1.mxkey dongle activated
2.ufs interface
3.ufc v2 cable
http://i768.photobucket.com/albums/xx323/raul_king123/SL389937.jpg
procedure...,
*open mx key
*select BB5
*put the ufc cable in 6151,like this..
http://i768.photobucket.com/albums/xx323/raul_king123/SL389931.jpg
*put the mu ,ppm ,cnt ..(the flash file must be higher than former version to prevent damage on phones software ,the old version shall appear when you scan or bus check the phone..)
*bus check the phone
*back up rpl first in mx key
*flash the phone and wait until it is done..
goodluck and thanks for trusting fixya..
Jun 20, 2010 | Nokia 6151 Cellular Phone
CANON IR4570 e000805-0000 AND e000110-001
on ir5570 error ,,E000110-001,,is polygon motor
Apr 05, 2010 | Canon ImageRunner 4570 | IR4570 |
I'm getting error code in my canon clc 2400 printer, it says e350-0000 what shall i do for it
perhaps you should think about using your "RESET" Button to reset your printer
Feb 21, 2010 | Canon CLC 2400 Color Copier
System error E808
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540 0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542 0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744 0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
Mar 22, 2009 | Canon CLC 1140 Copier
Settin up bluetooth
Turn headset off.
Hold down the "phone" button on the headset.
Turn headset on.
Release "phone" button.
LED ring should be alternately flashing red/blue.
Voila.
Jun 21, 2008 | Plantronics Pulsar 590A Wireless Headset
15 people viewed this question
jasbo
jasbo
