Question about Kitchen Ranges
What does regassing mean - Kitchen Ranges
  • 822 Answers
Regassing has to be done on fridges and freezers...............not kitchen ranges............
cheers
Posted on Mar 27, 2011
What is meant by E16 error code on my Kolin Brand Floor Standing A/C?
Means it running low on refrigerant gas and needs regassing.
Mar 13, 2018 | Office Equipment & Supplies
Deep freezer
The term re-gassing, is only used when you have a leak that hasn't been fixed. Freezers, Refrigerators and Air conditioners (both Home and Auto) never need to be regassed, unless there is a leak and that should be fixed.
Jan 06, 2014 | Imperial Kitchen Appliances - Others
How to recharge counter high fridge?
If you mean regass it then call a refridgeration company to do it as it is not possible without the vacuum pumps and gas bottles.
Apr 13, 2011 | Microwave Ovens
I did mean freezer not range
if you look at the rear of the freezer on the bottom there in a latge black can...........this is a compressor........which keeps the freezer cold................after time the gas inside dissipates............and has to be replaced......
regassed..........can only be done by cooling expert.............
cheers
Mar 27, 2011 | Kitchen Ranges
Air con fan works but no cool air the compressor doesn't appear to start
It may need regassing, air con runs out after a while as its 2005 it most likely needs to be regassed/refilled!
Jan 14, 2010 | 2005 Ford Futura
Aircoditioning not working, has been regassed
have you rechecked for another freon leak first
Nov 09, 2009 | 2002 Daewoo Leganza
A/c and fan takes time to blow air and sometimes it doesn't work at all
Do you mean it takes a while to get cold on A/C? It could need regassing. Take it to a mechanic.
Jul 19, 2009 | 2004 Infiniti G35 Sport Coupe
Not cold enough
An air con unit of any make should never need to be regassed if initially installed correctly. If it needs regassing, there must be a leak. You would have to find the leak and repair it before regassing, or it would be the same as pumping a tyre with a slow puncture. Generally most simplex systems use around 750 to 800grams.
May 09, 2009 | Heating & Cooling
Air conditioning problem
sounds like you may have a leak from pipe or condensor , have you had dye put in system ?
Aug 16, 2008 | 2007 Land Rover Freelander
Regassing of fujitsu splitsystem airconditioner
All split ac can be regassed, but if it was only installed recently and the gas has leaked out then it will either be a manfactures warranty job, or if it was poorly installed it should fall under the warranty of the installer. most cheaper installers however only give a 3-6 month warranty on thier work if they give one at all. If it is uses either R410 or R22 gas (it will say on the outdoor unit) than any liscensed and i stress liscenced installer can fix the leak and regass it.
Feb 13, 2008 | Fujitsu 36CS Air Conditioner
Kitchen Ranges Logo
152 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
