There is a system partition on the laptop that allows you to return the laptop back to how you got it from the shop. Please be aware that you will need to copy anything you have on there to an external drive otherwise it will be deleted on completion of the restor. When you first switch the laptop on hit the f11 key then choose repair your computer and choose reset to factory
First restart your Toshiba laptop. Press either "F1," "0," or "F8" to be taken to your computer's hard
drive utility screen. The key command differs depending on the model
Toshiba computer that you own.
Select "Restore Original Factory Image" from the list of options in
System Recovery. Verify that you want to continue the process by
clicking "Yes," then click "Next".
Restart the Toshiba laptop once the factory restore process has been
completed. You will be prompted to enter information such as the date,
time and language preferences.
Feel free get the reliable technical help at http://www.vtechsquad.com/toshiba-support/ for troubleshoot all kind of Toshiba PC(laptop and desktop).
SOURCE: I recieved error 10-FA12-045D after
Error codes starting with 10 on Toshiba laptops point to a hard drive failure. The drive is most likely dead and cannot be revived. You will need to replace the drive and then reinstall the operating system.
SOURCE: want to restore back to
when it starts up hit the f11 key, or hold down the esc and / or the delete. this will only allow the mainboard (bios) to be reset.
SOURCE: I want to restore my factory settings on my toshiba satellite
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
