Question about Garden
Troy Bilt Pony riding mower won't engage in gear. Belts appear intact.
  • 376 Answers
SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
Posted on Jun 19, 2009
  • 127 Answers
SOURCE: HOW DO I GET A MANUAL FOR LAWN MOWER AND ENGINE?
please double check model # and let me know
after the g sholud be a #then 11
13AN77KG_11
Posted on Jun 30, 2009
  • 202 Answers
SOURCE: I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Posted on Jul 31, 2009
dolharoobang
SOURCE: troy bilt pony riding mower will go in reverse but
have a troy-bilt riding mower. place a gear in neutral and park it.
it dies instead idling. want to know why?
Posted on Nov 14, 2009
  • 3911 Answers
SOURCE: How to tighen the built on a Troy Built Pony 42in
You can't really tighten the belt on any of these mowers.
First make sure you have the right belt, if you measured the old one when it broke
then you were not using the size it was before it got all stretched out from use. Find a manual
or look around online for a source to tell you the size the belt should be new and get one.
Second there is a tensioner arm, spring, and pulley which take up the slack, this may
double as a clutch to put in slack when you depress the pedal. Make sure the pivot for the
arm, the spring, and the pulley/bearing are all in good shape.
Third there are belt guides which can also be worn and create slack, so check those and make sure
they are in good shape as well. I may not be the only one who ever put a belt on the wrong side of a guide.
Lastly make sure you have the belt on correctly, and nothing is bent, split, or warped.
Posted on May 03, 2011
I need the belt sizes for my Troy built pony riding lawn mower there are three belts
then go to a troy bilt dealer with model number and see what they can get for you .fixya does not sell any product .
Mar 18, 2018 | Troy Garden
How to adjust drive belt on troy-bilt pony tractor
pony lawn mower? replace the drive belts.
Mar 04, 2017 | Troy-Bilt Garden
Mower belt diagram
Try Goggle it. belt diagram troy -----
Aug 03, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Troy bilt zero turn mower runs but does not move
Make sure the gears are engaged. There are 2 metal hooks on the rear of the mower, 1 on each side, if they are pulled out the mower is out of gear, make sure to slide them over so they retract back into the mower. If not the problem, sounds like either broken drive belts or the transmission isn't working properly.
Jul 02, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
I have a troy bilt 17.5 hp pony riding manual lawnmower and my belt located above the deck keep jumping off track after engaging the blades a couple of times,do i need to tighte my belt,if so how?
Those units are self adjusting. No way to adjust it. It sounds like you have a bad idler pulley or a bad spindle bearings, which would cause the pulleys to be out of alignment.
Sep 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Troy bilt pony riding mower will go in reverse but grinds in forward where do i start
Jul 17, 2009 | Garden
Garden Logo
297 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
