Question about Acer Computers & Internet
The screen flicker on and off and then fades out. It is not the battery. sometimes if you touch the laptop it just turns off.
  • 822 Answers
Lose connection near top of keyboard.............
cheers
Posted on Mar 27, 2011
    Genius:
  • 1,288 Answers
Could be one of three things:
1.) Failing inverter (which powers the screen up). Given what you describe, if it is the inverter, it may be that the connection is loose to the screen. The inverter converts the 20 volts or so from the laptop to a much higher voltage and relies on a tight fitting.
2.) Failing backlight (this is the light that illuminates the screen after getting a charge from the inverter.) Again, this can also be a loose fitting of the cable between the inverter, the connection to the motherboard and the 30pin connection to the back of the screen.
To test this, connect the laptop to an external monitor, if the monitor stays on, then the problem lies in the above (it may also be a faulty VGA cable between the screen and motherboard, but unlikely)
If it is the problem, you will need to get the inverter and screen tested.
After that, and if the problem occurs ONLY on AC power, I'd suspect that the charger might be throwing out intermittent voltage. Test this with a multimeter set to 20 volts at the DC jack end, with the red probe in the inner of the connector and the black probe in the outer of the connector.
Check also the tightness of the DC jack in the charging port
3.) More serious... the graphics chip may be overheating, this occurs when there is a build up of dust on teh cooling fan, If you have the model with the large plate underneatth the laptop , remove it and clean out the components.. try again and see if this fixes the problem.. if not, then you will need to get it stripped and cleaned by a competent technician (or take the time to do it yourself).
If none of the above work, then you have a failing garphics chip and will need to consider replacing the motherboard
Acer aspire e1
This sounds like a driver issue. See if there is a driver update from Acer.
Mar 09, 2014 | Acer Aspire Computers & Internet
Screen on Sony lap top fades to grey Touch pad and mouse not responsive
as for the lines its natural the camera is picking up the the pixels flickering. as for the mouse and your screen turning gray its either one of the following.
1. Motherboard is going bad or contacts inside are not centered(which means the mousepad isnt sitting on the sensor that picks up your finger)
2.you have disabled the mousepad via the FN keys on your keyboard
as for the grayness im not quite sure as i cannot see it via the video.
hope this helps
George :)
Nov 14, 2012 | Computers & Internet
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
My Packard Bell (bought May 2010 new) laptop has a screen flicker problem. For the past week, every now and then the left half of the screen, or sometimes the bottom half of the screen, gets distorted with...
<font size="3"><i><span style="FONT-FAMILY: Arial; COLOR: #cb0101" lang="EN-US">4400mAh, 11.10V</span></i><span style="FONT-FAMILY: Arial; COLOR: #333333" lang="EN-US"> Dell Vostro 1710 Battery Replacement<span style="mso-spacerun: yes"> </span></span></font><span class="redfont1"><b><span style="FONT-FAMILY: Verdana; FONT-SIZE: 16.5pt; mso-bidi-font-family: Arial" lang="EN-US"><font color="#cb0101">$ 72.58</font></span></b></span><br /> <span style="FONT-FAMILY: Arial; COLOR: #333333" lang="EN-US"><font size="3">Dell Vostro 1710 Battery</font></span><br /> <span class="htmlval1"><span style="FONT-FAMILY: 'Courier New'" lang="EN-US"><font size="3"><font color="#0000ff">Discount Dell Vostro 1710 Battery 11.1V 4400mAh,fit for Dell Vostro 1710, Dell Vostro 1720 Laptops.Full 1-year warranty and 30-day money back!</font></font></span></span><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">ShippingArea:</span></b><b><span style="FONT-FAMILY: Verdana; COLOR: #cc0000; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">We ship all over the world!</span></b><b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US"></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Brand :Dell Vostro 1710</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Type :Li-ion</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Voltage :11.10V</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Capacity : 4400mAh</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Ltem(Cell):6-cell</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Color :Black</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Dimension :270.90 x 50.00 x <st1:chmetcnv w:st="on" tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="20.2" unitname="mm">20.2mm</st1:chmetcnv></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Weight :<st1:chmetcnv w:st="on" tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="665" unitname="g">665g</st1:chmetcnv></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery SKU :DE017K</span></b><br /> <span lang="EN-US"><a href="http://www.battery-sale.net/dell-vostro-1710-battery.html">http://www.battery-sale.net/dell-vostro-1710-battery.html</a><span style="mso-spacerun: yes"> </span></span>
Aug 27, 2010 | Computers & Internet
My hp pavilion dv6000 laptop does not turn on, the blue buttons light up, but the screen stays off
Try it without the rechargable battery connected sometimes the battery shorts and causes problems.
Do you have FN[function] keys at the left side. touch FN key with something else and see if screen comes back.Sometimes you can turn off the screen to send it to the back connected monitor.Connect (extra if you have) an external monitor to the back (vga) connector.If that shows, then you have to ""flutzz" with the FN(function) & F1-F12 keys
Nov 28, 2008 | Computers & Internet
The laptop screen
This is going to be a hardware issue. Start by checking the screen connections, they sometimes work loose. If the connections are good and the problem persists, it's going to be the inverter or screen, and unfortunately, replacement is your only option.
Jun 28, 2008 | Dell Inspiron E1505 Notebook
Laptop screen sometimes flickers and gets jumbled up
it could be a problem of the lcd cable.
to fix this..the notebook needs to be opened up and lcd cable needs to be reseated
Jun 27, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Computers & Internet Logo
56 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
