Question about Cameras
Kodak EasyShare C142 keeps freezing and wont do anything. After I tried to take the batteries out while camera was still frozen, it finally shut off. Then when i try to turn it back on the lens makes a weird noise.
  • 10 Answers
SOURCE: kodak EasyShare lens makes clicking noises
try going into the menu 8 clicks down onto theaf control,and make sure its on single AF ,not continuous,as if its on continuous it will keep trying to stay in focus,if this dosent solv it its probabley a faulty lens
Posted on Feb 07, 2009
SOURCE: When I turn the camera on it makes a few noises then shut off
i called the company (1-888-553-4448) olympusamerica.com and they told me to send it in and they will repair it for 70.95 plus a 6months warranty because i cant find my reciept. they also said what eva is wrong with it they will be able to repair it, but if u have ur warranty u can send it to them it wont cost u anything because u have ur reciept.
Posted on Mar 23, 2009
BillB-SA
  • 2761 Answers
SOURCE: Kodak Easy Share V1003 camera is frozen. Turned
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
  • 68 Answers
SOURCE: Lens error 10e,1,10- Kodak EasyShare M753
this is an hardware error. I'm sorry but you can't fix it by yourself. You've to contact kodak for a repair.
Posted on Oct 16, 2009
leepania
  • 1099 Answers
SOURCE: my kodak easyshare lens keeps shutting off. the
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 11, 2009
Camera freezes when I try to review pictur
My advice is to remove the card and back up the photos on a computer, then format the card from computer then from camera. Test, if it still freezes card is probably dead.
Cheers
Oct 25, 2014 | Kodak EasyShare C142 Digital Camera
What is all the types of memory cards for a Kodak EasyShare c142
the lack of replies suggests you'd be better off putting a memory card into anything else other than a Kodak easyshare..... just look on here at the amount of Kodak & easyshare problems there are....... but for the record, "GOOGLE" mentions 32GB works fine and class 4 or over.
Jan 01, 2014 | Kodak EasyShare C613 Digital Camera
I got a Kodak EasyShare C142 and when i take a video it has no sound how do i put sound on?
I found this information on Amazon regarding the camera and it makes sense but I haven't tried it. Since the camera has a microphone it can record sound but there is no speaker so you can't hear anything during playback on the camera. You have to upload your videos to a computer (with speakers) to actually hear the recorded sounds.
Jan 04, 2011 | Kodak EasyShare C142 Digital Camera
How to charge kodak c142? is the data cable which is used for copy the pictures to the PC also charge batteries?
I don't believe these batteries with this camera are rechargable. the spec sheet calls for alkaline batteries. Do the batteries in the camera say rechargable on them. There is a Kodak battery charger with batteries , but that is a multipurpose charger for many cameras, and all it does is charg batteries like any other batter charger.
Nov 27, 2010 | Kodak EasyShare C142 Digital Camera
My Kodak EasyShare C142 keeps telling me that it cannot read the 2G memory card. I have had the same memory card since I bought the camera new 2 months ago I just took pics with it 2 days ago and when I...
The card may have become corrupted. Use a separate card reader and download any pictures from the card. Then, insert it into the camera, go into the menu and find "format"...follow the on-screen instructions.
Oct 08, 2010 | Kodak EasyShare C142 Digital Camera
My Kodak Camera C142 does not want to switch on, what should i do? I was takig pictures with the battary still full and it just switched off and wont turn back on. What should i do?
If you have not used your camera for few months the problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try solution before you do anything else:
Step1: Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper).
Step2: Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Thank you !!
Aug 02, 2010 | Kodak EasyShare C142 Digital Camera
Cameras Logo
120 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
