I have an 47LG5000. I was trying to get the USB to work, and accidently changed the "Tool Option 1"-number to zero. And now the whole TV is **** up. Can't see anything on the screen.. I have no idea what the 5-digit-code is. Please help!
The channels keep changing and won't stop at any of the as if the up button is stuck
Posted on Feb 22, 2012
No buttons work on LG 47LG5000. Neither remote nor the TV side buttons work but I can access all features by holding down 2 buttons for 15 seconds (eg. MENU and INPUT held together first brings up the...
check to make sure you have power to unit. If you do you may have a internal power problem. Have you gone thru a recent lighting storm? If so see your home insurance co. For coverage to repair or replace unit.
Feb 07, 2014 | LG Televison & Video
Tip
How to activate USB on LCD TV LG's latest generation (LH2000, LH3000, LH4000)
When I got the TV, the LG LH2000, with a diagonal of 32 inches, I was a little disappointed when I realized
that the model that I bought does not work behind the USB port on your TV . I was explained that it is only
for service (software upgrades and the like). I did not beat your head too much and I accepted the
situation.
What would help me? I miss writing movies on CDs and DVDs. Copy just the files on a USB stick, insert it
into the port behind the TV, go into menu and select USB. It's like a DVD player. These days, I discovered
that I can retire the DVD player, because now I can enable the USB and still use it. How?
In a few easy steps.
1.Press the same time the OK button on remote and OK button on the TV and hold down for about five-six
seconds
2. Asking a password - using the buttons on the remote, enter 0000, then press OK
3. Upper left corner of your screen will show the service menu
Well, here's a little more complicated and should be recommended to strictly limit yourself to three
settings below. WARNING! Where do additional settings without knowing exactly what use, you are solely
responsible for the potential disruption of the TV and also for the possible loss of warranty!
Once the service menu appears, select the third option (number 2, named TOOL OPTION3). Do not confuse 2 with
3. The numbering starts with 0, not 1, will therefore TOOL OPTION3 will be numbered with 2.
In other words, select the option marked in yellow as the image on the right. I suppose you can select with
OK, but I entered in navigation settings press the "right" button on the remote.
Following two settings:
1. Once entered in the TOOL OPTION3 menu, select the EMF (JPEG, MP3) and using the "right" button of
navigation on the remote (to be clear, "right arrow"), select option 1.
2.A second, and final setting is highlighted in yellow in the image on the right. At DivX choose HD.
And now important!, In any form do not press OK from the remote! Press Exit button(Return), located in the
lower right-hand navigation menu.
What happens after these settings have been made? In TV menu will be two new options: Input and USB. We are
interested, at present, USB. What should I do to see movies? In this order:
1.Introduce stick into the USB port on the back of the TV
2.Press Menu button on your remote and select the USB
3.Select movie files (or something like that, anyway you got options for MP3 or photo)
4.se will open a variety of browser, similar to those on DVD players
5.Search for desired movie and press OK
Integrated player in LG television support DivX. I put a stick on an episode of TopGear and I saw with no
problem. Using left-right arrows, you can run the movie. For a typical player buttons (Play, Pause, Stop),
they use those colors (they are marked otherwise) on the remote.
Enjoy.
on Jul 20, 2010 | Televison & Video
Large factorials ti84
The TI-84 is limited to numbers with at most twelve significant digits.
If you must know the EXACT value of 16!, try this. Calculate 14!. Note the two zeroes at the end. Strip them off by dividing by 100 and remember the two zeroes. Multiply by 15. Strip off the last zero by dividing by 10 and remember that we've now stripped off three zeroes. Multiply by 16. Add the three zeroes at the end to get a fourteen-digit number.
In this particular case the result is exactly what you get by using the FACT function. That's also true for 17!, but it breaks down past that because 18! has more than twelve significant digits.
The whole point of the calculator is to allow you to do calculations with a reasonable degree of accuracy, as opposed to exactly. You'll notice that it can't do a simple operation like dividing 1 by 3 and produce an EXACT answer---only a twelve-digit approximation.
Oct 03, 2012 | Texas Instruments TI84Plus Graphic...
C++ error is appears
Error "Microsoft Visual C++ Runtime Error..." appears on launch
Problem:
When launching PDF Converter Professional 4, a Visual C++ error may occur which refers to autoupdate.exe.
Cause:
This issue may occur if there is a conflict with the Auto Update tool.
Solution:
In order to resolve this issue, we recommend using either of the following solutions:
Option 1 - Edit the system registry
  1. Click on Start > Run.
  2. Type "regedit".
  3. Navigate to HKEY_CURRENT_USER\Software\ScanSoft\PDF Professional 4.0\Config\
  4. Click on AllowWebUpdateOnInit = 1
  5. Change the 1 to a 0 (zero).
  6. Navigate to HKEY_LOCAL_MACHINE\Software\ScanSoft\PDF Professional 4.0\Config\
  7. Click on AllowWebUpdateOnInit = 1
  8. Change the 1 to a 0 (zero).
Option 2 - Disable automatic updates.
  1. Disconnect the network connections by doing the following:
    1. Click on Start > Control Panel > Network Connections.
    2. Choose each, right-click and chose "Disable".
  2. Try to launch the program.
  3. Disable the automatic update by clicking Help > Nuance on the Web and uncheck the Automatic Web Update entry.
Jul 21, 2011 | Computers & Internet
Trying to factory restor my lg 9800 but dont have security code since I bought phone used how can I reset to erase all the previous owners **** ?
1 - Open the Flip
2 - Press MENU >> Then ' 0 ' [ zero ]
3 - At the Service Code prompt enter six zeros
4 - Choose option 12
Phone should REBOOT and RESET to Factory Defaults... But, if you want to go to the pre-activation stage, that's a different process...
1 - Flip Open, Press Menu
2 - Press 0 followed by 000000 [6 zeros at the Sevice Code Prompt]
3 - Choose Option 1 [ Service Program ]
4 - Click the OK soft button [brings you to the * Phone Number (MDN)* screen]
5 - At that screen enter 10 zeros - to replace your current phone number
6 - Click the OK soft-button
7 - At this screen repeat step number 5
8 - Now click END
Phone will REBOOT by itself and the screen will now display " Initial Programming Required " - This is what the Sales Rep sees when he/she opens the box and boots the phone the very first time to program it to your account
Nov 25, 2010 | Cell Phones
My lg lcd tv has a usb port but only recognises photo and music. I would like to be able to play movies using the usb.Is this possible and if so how??
You need to activate it first, here are the steps:
1. Press the enter(OK) both on the remote and the TV at the same time...hold for about 5 seconds
2. Password - 0000
3. Go to tool option 3
4. Change Jpeg to 1
5. Change Divx to SD or HD
6. Exit and try it out.
You will notice that now there are 8 inputs in the option list instead of 6 - Including a USB input.
Hope this helps
Nov 04, 2010 | LG 42LH30 42 in. LCD TV
What is the meaning of whole numbers?
no decimals (1.5, .56) no fractions (1/2, 1 3/4)
whole numbers are just whole numbers
1, 2, 3 and on 9,10,11 .....
not
1.5, 2.5, 2.356
1 1/5, 2 2/6,3 1/5
Jun 19, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
My computer detects 4 Gb pendrive (S/N 5282015959 & model TS4GJFV30 but does not open.In properties shows zero bytes but device full
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
3.b) Format pendrive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 30, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
On inserting the pen drive,its showing that no disk is inserted into H drive.And on seeing the properties of the pen drive,its showing Zero MB free and Zero MB in use.Its not even being formatted or...
1. Download this tool:
2. Format
Jul 07, 2009 | Pen Drive IVO MP3 Player
Service Remote
Sorry, I'm not a problem solver. I had ask a question myself several month's ago that went unanswered. My tv is a LG RU44SZ63D. Through my own diligence I discovered that the special set-up remote for accessing the service menu is a 105-201M. I have no idea how many different model tv's this remote works on. I purchased the remote from www.newremotecontrols.com. It "IS" a tool and unfortunately doesn't come with instructions...
Oct 20, 2008 | Televison & Video
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
