Whirlpool model # GHW9250MW1 Frontload washer,just installed and ran a load leaking heavily from lower right front and I am in need of some instructions to handle it myself,as well inexpensive parts dealer. I am not looking for a freebie and if given a some assistance I will pay via my paypal account directly to the expert that succesfully gets me through the repair
  • 3 Answers
SOURCE: repair front load washer
We've had that same problem since we bought ours 3 years ago...but it was intermittent, and we never knew when we'd get the spin-dry cycle to work. Sears made 10 service calls, and replaced everything in the machine except the motor and motor control board. Those two parts were ordered and delivered as a result of the 10th service call. Of course, when the service guy was here, the spin worked! After he left, the next load did not spin. Frustrated, I opened the front end and looked around. I had noticed how violently the drum shook while operating when the service guy was here, so I decided to see if the wiring harness from the motor might be loose where it plugs into another harness that must go to the motor control board. There was a definite tightening of that connection as I squeezed the two harness plugs together. (I tightly secured a plastic zip-tie around that connection to prevent it from vibrating loose again) Since then, I have had absolutely no problem with the washer. I called Sears and told them I had managed to solve this long-standing problem on my own, and how, and also told them to cancel the service call to install those parts I ordered, but to pick them up and reimburse me for them. (I never opened the two boxes that arrived) They did just that, and we finally have a washing machine we can rely upon to complete the wash like it's supposed to. It's been a very frustrating and expensive 3 years, but now all is well.
Posted on Jul 04, 2007
Sounds like the same issue I'm having, I will look at the area you suggest.
thanks,
Rog
Posted on Dec 24, 2007
  • 4 Answers
SOURCE: Tub seal has rip therefore washer is leaking.
noavatar_s.png marklfixit
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Replace the front bellow or front seal, as it may be called. It is an inner tube shaped rubber liner that seals between the front of the washer door and the front of the drum. The cost is about $35.00-$40.00 and you will need the kit as it includes the rubber spacers that are essential to doing the job. The job takes about 1 1/2 hours to complete. It is not hard, but it is dedious and requires some basic skills. Directions included in the kit are helpful. You can do an internet search for the part and many appliance parts shops will carry the part. Do a search for appliance parts in your area and see if they carry that part on line, or you can call them tomorrow. I imagine a pair of strong hands would help as you seperate the outer groove that goes into the drum lip, then replace the spring that holds it in place there.
Posted on Jan 24, 2008
aborcass
  • 2651 Answers
SOURCE: whirlpool duet frontload washer leak
a quart of water over the course of a cycle is pretty significant, other then trying to remove the fabric softener section looking for a blockage in the dispensor(which is basic and should be real evident ) theres not much more for you the consumer to look for.(or should you have to for that matter its why you bought a NEW appliance). As for the service , you've purchased a Whirlpool product, therefore you can call any whirlpool authorized Company out to service you dont need to wait for Sears!!!!!!!
Posted on Mar 18, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Duet front loading washer - handle broke off
heres the part number, you can call whirlpool or google it and find on the web part number 8181846, easy enough to relpace
Posted on Dec 04, 2008
My Whirlpool GHW9250MW1 knocks very bad especially on the final spin cycle. Do I just need to get a new washer?
Before junking your washer, remove the rear panel and be sure the large pulley is tight. If it is, the spinner support is likely broken on the tub assembly. That repair is major and very expensive. Check the pulley with fingers crossed....
Kelly
Mar 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool frontload washer with model number WFW83005W00 and I have an error code F21 that flashes and then the washer stops working. What does this mean and what should I do?
Means the drain is taking too long . Most likely that the drain sump filter is blocked. Remove the lower front panel and unscrew the large white thumb screw attached to the pump. Water will come out so collect it then clean and replace.
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do I unlock my frontload whirlpool duet washer
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front load washer is giving a F 11 error.
power failure--------unplug the unit for 5 minutes and see if it clears that code
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hello. My frontload LG Washer started leaking
I have the same problem I think. During the wash cycle, water sometimes starts spraying/leaking from the detergent dispenser drawer. This orignally only happened during a 'NORMAL' wash and when I ran a 'SPEED WASH' it was ok. Now all of a sudden it's doing it during the 'SPEED WASH' also. I though it might be the water pressure so I turned down the flow going to the washer but that doesn't seem to help. If I knew how the detergent system worked maybe it would be easier to solve this problem.
Nov 11, 2009 | LG WM2277H Front Load Washer
KENMORE FRONTLOAD WASHER Model# 41741052000
very common for the tub seal to leak - or bellow to be ripped.
Aug 07, 2009 | Kenmore 44102 Front Load Washer
Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Apr 09, 2009 | Whirlpool WFC7500VW Washer
Whirlpool doet washing machine
the door on any frontload whirlpool washer cannot be changed from side to side.only the dryer
Sep 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from my whirlpool frontload washer
open the door and check between the drum and door frame. There is a large rubber bladder completely surrounding the drum. Pushing the drum further back into the machine will let you see the entire thing and unfold it. These often get small laundry like socks stuck there as well as sharp objects like nails. You may have a tear in it which will leak like that. Replacement parts run about $70.00.
May 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet frontload washer leak
Mar 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
