Question about Enterasys B3G124-24P 24-Port Gigabit Ethernet Switch
When I boot the Enterasys the CPU light flashes yellow and then red. It looks as if it never boots properly
PS3 yellow lights won't turn on
You may have the yellow light of death. You get the yellow light of death when the playstation stays on too long or alot of use or it may taken some damage.
May 09, 2013 | Sony Playstation 3 (PS3) Console
It wont turn on
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 14, 2011 | Computers & Internet
Hi i have a 8220 and red light is blinking on charging. I have checked very possible thing even the charger but cant get around pls help! thanks
Please don't worry this is caused because of various reasons.The lights explains what could be the problem
Orange and Yellow lights mean no defects in the mobile.Orange is phone battery is very low.Yellow is for boot up..
Red light means-You have power management problem.
You have to understand why it is being caused..
1)Due to dead battery.The phone will charge but you phone battery will not get charged it acts like it is getting charged.Behind the scene it cant store the charge.
2)Due to charger is not working properly no charge in the battery.
So you have replace this accordingly..
Please try this some time phone booting may be stopped,
This is not a solution when the battery is dead or fully down....
Sometimes The boot cycle of the phone is stopped.You have to start it.Remove the battery and place it again and press the red 'end' button continuously until the red light flashing stays on.Press green button' call' button and hold the red button...Now press these two buttons alternatively until you see hour glass symbol.Now when you see hour glass wait and see the phone booting....
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Ps3 starts up, fan is very loud, red light flashes and shuts off
Your most likely cause is the CPU or GPU is damaged due to over heating. This is usually not repairable. Red flashing lights are usually a bad hard ware warning. Try looking up flashing or fault codes for PS3 light patterns and check if any match up to the flashes you get. Another thing to indicate hardware failure is if it boots up at all. I'd like to give you better news but this is more then likely more an autopsy report then anything helpful.
Mar 30, 2010 | Sony Playstation 3 (PS3) Console
Any time i turn on my ps3 it will turn off
HI If the light turns yellow then red, this is a overheating issue. let it stand for an hour unplugged to cool.
Now, if the green light doesn't turn yellow before red, this will confirm that the HD(Hard disk), is experiencing some difficulties with the booting process. This will occur if the internal connections are damaged, due to a solder break. In this case, you will need to send the unit to Sony for a repair. Try removing the HD from the unit. after the unit HD is removed for a minute and re-installed, try to power up and initiate a boot. if the unit continues to not boot and flashes the red light after the HD is pulled, this will confirm that the HD is the culprit.
Contact Sony for a repair ticket if the problems persist.
Oct 03, 2009 | Sony Playstation 3 (PS3) Console
From standby PS3 wont turn on.
that sounds like your main power supply unit
May 28, 2009 | Sony Playstation 3 (PS3) Console
I have had my playstation 3 for almost a year and a half. Out of Warranty. It has worked great until just last week. Now when I turn it on, It turns on for a second, seems like it is trying to boot up,...
There isn't much you can do but go ahead and google rescuetechla and look for my blog. you can try a few of the solutions. Most of the time it's a cpu / gpu problem that I don't recommend the average user try to fix themselves.
May 13, 2009 | Sony Playstation 3 (PS3) Console
[Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Apr 27, 2009 | Dell Dimension 8400 PC Desktop
Packard Bell Imedia 1402 wont boot up
you did not install the new Hdd properly, the part of the ribbon cable with colour should be by the side of the power connector and the power connector should be connected with the red cble by the side of the colour on the ribbon cable.
uzowuanya
e-mail:uzowuanya@yahoo.ca
Oct 03, 2007 | Computers & Internet
Enterasys B3G124-24P 24-Port Gigabit Ethernet Switch Logo
239 people viewed this question
Top Enterasys Computers & Internet Experts
George Nalley
Level 1 Expert
Jax Planet
Jax Planet
Nathaniel Berrios
Nathaniel Berrios
Are you an Enterasys Computer and Internet Expert? Answer questions, earn points and help others
