Question about Nokia Mirafone OP201 Phone
I have a Nokia 3110c, and whilst transferring music from my PC to my phone, the phone switched off due to low battery. I then charged the phone and it reacted normally, until this morning when the phone will no longer turn on, but will still charge. Any ideas how to get it working again? Thanks for your help in advance.
  • boris1993 Aug 04, 2008
    Nope, unfortunately it didn't work, but thanks for your help anyway :)
  • 3 Answers
I have nokia 3110 c too. The music player in nokia 3110c read some kind of codec or what ever in the music file, when u update the library or u turn the phone on. If something happen with the music file, (it usually because by the music player from computer) the phone will cannot read it, so it will restart. And read it, and restart again and again. What to do is, open your memory card by card reader and delete the music file that u have put in it. Then its done, don't forget to reinstall the music player at your computer.
Posted on Jan 19, 2010
  • 27 Answers
I have had problems from running my phone during low battery these smart phones store a copy of their firmware in no volatile ram that can be corrupted during low power or loss of power. this is why you should always turn your smart phone off before removing the battery.
Try a Hard  reset
This will wipe the phone of contacts and photos and calender entrees.
also a hard reset can be performed by. turning the phone off, holding *, 3 and the Green call button and powering the phone up. keep holding the buttons until the phone makes it start up tone. At this time you will be prompted to re setup your phone.
Also the phone will not start if the battery I not able to provide enough charge. if you have run it that flat before then it will likely to fail prematurely
Posted on Jan 06, 2009
I have a nokia 6300 in this earphone not working this connector is no problum
Posted on Sep 16, 2008
    Problem Solver:
  • 18 Answers
Remove the battery and and place it again and try switching on the phone.
Posted on Aug 04, 2008
My nokia 3110c phone restarts 2 to 3 times....n then it gets switch off
Hi!
There are many solutions for this issue, please check and try the one that applies. Make sure you back up any data before proceeding.
- Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
- Don't get your phone loaded with too many themes downloaded from the internet or atleast, don't switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
- Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
- Don't try updating of music library frequently or don't often transfer data in/out of your Nokia 3110c phone.
GoodLuck!
eBookBoy
Jul 11, 2011 | Computers & Internet
My nokia 3110c is not switching on properly it auto matically switching off within 2-3 second yesterday i had download some wallpapers from internet it might be due to virus so what i should do
That is the your battery charge problem. your cell phone battery doesn't give sufficient back up to your cell phone. first charge your battery full charge then try. otherwise change your battery.
Aug 22, 2010 | Nokia 3110 Cellular Phone
My nokia 3110c got switched off. then when i
Nokia 3110c while charging the battery& while taking its got switched off.
Jul 26, 2010 | Nokia 3110 Cellular Phone
Can u help me to format my nokia 3110c phone???
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Jun 29, 2010 | Nokia 3110 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
I'm having trouble when switching on my nokia 3110c
hey i have a solution but its quite rough though... take out all your memory card and sim card and battery... then without the battery press the on button. just put in the battery and keep holding the button. if it still restarts then take out and put the battery in again until it will start. this really works as it works for me 5 times when i had this problem. but the only thing i'm scared is that it might damage your phone. but once you have this problem your music player will be spoilt already. my music player was also spoilt but it works twice. now it doesnt work though. im not sure about music player
Aug 11, 2009 | Nokia 3110 Cellular Phone
3110c
got this from the net, maybe it helps:
The Problem with Nokia 3110c – Switching off and automatically restartingThis is what happens. Nokia 3110 hangs, gets switched off andrestarts randomly. More often, it restarts around 3 times or so andthen gets switched off.
Possible Causes and SolutionsCause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500KB, so as to keep things running smoothly on your phone and preventNokia 3110c from restarting.
Cause 2 – Changing Themes – Some people havereported that the phone restarts automatically when they try changingdisplay themes on the phone.
Solution – Don’t get your phone loaded with toomany themes downloaded from the internet or atleast, don’t switchthemes frequently. These themes, mind you, also load up things intoyour already falling Nokia 3110c phone memory.
Cause 4 – Transferring data via Blueooth / USB datacable (or) Updating Music Library – A few people have reported thattheir Nokia 3110c mobile phone restarts when updating the music library.
Cause 5 – MP3 files
Solution – This may seem dumb, but considerconverting all your MP3 music files to WMA and then store them on thememory card. Some users suggested this.
Disclaimer – Follow the suggested solutions at your own risk. The author is not responsible for any damage caused to your phone.
UPDATE:IT LOOKS LIKE A FIRMWARE UPDATE COULD FIX SUCH NOKIA 3110CRESTARTING PROBLEMS – RESOLVE YOUR ISSUES RIGHT NOW BY UPDATING YOURNOKIA 3110C FIRMWARE – CLICK HERE TO KNOW HOW YOU CAN UPDATE YOUR NOKIA PHONE FIRMWARE
Jul 23, 2009 | Nokia 7610
Automatic restarting problem with Nokia 3110c mobile phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Cause 5 - MP3 files
Feb 12, 2009 | Nokia 3110 Cellular Phone
Nokia 3110c music player not working
my nokia 3110c music player updates continuously but does not start
Feb 09, 2009 | Nokia 3110 Cellular Phone
Formatting internal memory of nokia 3110c
Cause 5 - MP3 files
Jan 14, 2009 | Nokia 3110 Cellular Phone
Nokia Mirafone OP201 Phone Logo
219 people viewed this question
Top Nokia Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Nokia Lands Phone Expert? Answer questions, earn points and help others
