Question about Microwave Ovens
Fridge not working freezer ok - Microwave Ovens
  • Microwave Ovens Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 27, 2011
Zanussi freezone fridge freezer
Try adding freeon made for refrigerator. Can get at any hardware store. Hope this help.
Sep 09, 2013 | Microwave Ovens
Miele Fridge Freezer not getting cold
Power off and remove all fluff under the fridge.
Compressor can be hot but not too hot. Are the settings ok for desired level cold. Is the fridge too heavily loaded? Try now.
Aug 07, 2013 | Miele Microwave Ovens
The freezer is working but not the fridge fridge onm top freezer below I think it my be the thermostat
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Microwave Ovens
Fridge is cold and freezer works but condensation dripping into main part of fridge - everything is getting mouldy - help?!
heatman101
Aug 31, 2011 | Microwave Ovens
Started icing in freezer compartment so i defosted 4 24hrs. switched back on now freezer not working at all in fact its getting warm in freezer compartment fridge seems ok compressor seems 2 get quite hot...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 25, 2011 | Microwave Ovens
Sub zero 532 fridge is not cooling porperly but freezer is fine
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Jul 09, 2011 | Microwave Ovens
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
Hi there. I have had my fridge freezer for about 1 and half year,but the fridge is not working.The freezer works perfectly fine. can you help please? Thnx
I suggest that half of the system is not working and recommend the services of a refridgeration engineer as it may need re gassing.
Jan 08, 2011 | Microwave Ovens
Fridge not working but freezer is ok!
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 24, 2010 | Zanussi Microwave Ovens
My freezer is working but the rest of the fridge is hot
Hi, it is possible for your freezer to work when you fridge is not working. Fridge-freezer appliances have independent controls which can malfunction separately. If your freezer is fine and your fridge seems down, there are several things that could be wrong but what i suspect is that... You should check the damper door located between the freezer and fridge compartments to make sure it opens and closes, sometimes they get an ice build up there and this causes them to stick shut, remove ice with hair dryer or remove and device and replace this will solve your trouble.
Best of all is to call in a local fridge technician around to get it fixed, it won't cost you much...
Take care
Feb 18, 2010 | Magic Chef Microwave Ovens
Microwave Ovens Logo
169 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
