I have whirlpool washer model number is SM8525147-A. when its put on it will fill to which water level is required but it does nothing after that. A few weeks ago it had stopped completely but when i raised the cover and closed it a bit hard it started back to work until now. do you have any solutions for me. Thanking you in advance
  • 249 Answers
SOURCE: Smart drive Pride 5.5
can you empty the machine completly of water, and start again.you could try unpluging it for 2 mins it might reset it self best of luck!!!,close,eire
Posted on Dec 15, 2007
AlmostBob
  • 550 Answers
SOURCE: Filling With Water
If the water continues when electricity is discontinued the soleoid valve is jammed open, a fleck of rust or something, not designed to be repaired, it is easier and cheaper to replace. they are a standard part that fits 99% of all washers ~$10-20 at the local parts guy.
Usually only the cold solenoid has failed. it gets used more often.
If you are like me and only use cold water, swap the hoses on the taps, and swap the wire connectors on the solenoid valves, so the former hot is now cold, and you will get about the same number of years before you have to replace anything
Posted on Jul 29, 2008
  • 409 Answers
SOURCE: Water Overflow
hi there,
i would recommend checking the water level switch or lid switch and also the cable leading to it. that is what sends a signal to the machine control to stop filling with water.
Posted on Oct 11, 2008
SOURCE: I can't find the model number on washer Whirlpool Ultimate Care
Model # and info is under the lid. Open lid and look directly under it - area facing you. You should see a small silver tag with all the factory info on it. My washer is also 9 years old.
Posted on Dec 16, 2008
rylee_smith
  • 8619 Answers
SOURCE: F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Posted on Feb 08, 2009
I have a Whirlpool ZUltimate Care II Washer, Model 3XLSQ7533JQ2. Washer keeps filling in the medium and the super wash level and will not go into the agitation cycle. Works on small load level only.
SInce the washer works ok on the small load size yet overflows on all others the problem is going to be with the water level switch and it should be replaced to remedy that problem.
The part number for that water level switch is W10339229 it could be purchased at your local appliance parts store or online at
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Oct 13, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool sm8525147 just stopped working after it filled up with water. I tried seeing if it tripped the breaker.
most likely the timer has quit but without more info I can't say for sure. This is typically what happens when the timer quits or burns up.
Nov 10, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool LLR7144DQ0top load. Replaced coupler, now nothing works
Check list:
Motor plugged back in
capacitor reconnected
lidswitch reconnected
timer connection secure
water level hose is not pinched
She oughta take off
Service manual for direct drive and more videos
May 24, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer overflows. it wont stop putting water
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.########) and you'll see a list of major sub-components with diagrams and parts.
(The 110 means that it was manufactured by Whirlpool, you also need to enter the 8 digit model number)
Also see the Whirlpool / Kenmore Service Manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It has testing procedures as well as a good description of how the washer works.
It sounds like a defective water level switch or water inlet valve.
See the following for how to release the console and cabinet on these machines in order to get to the switch for testing.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Basically, what happens is:
When the washer is turned on, the water inlet switch is closed allowing water to flow thru the inlet valve. When it senses that the machine is to the level selected by the water level dial, the switch opens shutting the inlet valves.
If the switch or valve is defective, water will continue to enter the machine.
The Whirlpool Service Manual has testing procedures (basis continuity tests with a multimeter) for both the switch and valve.
May 10, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool Washer model # LSN1000KQ0 overfilling
did you plug the hose back into the water level switch, double check to see if it is plugged, if it is your water level switch might be defective. trouble shoot by taking the front panel off... turn on the washer by using the timer, set water level to small...on the bottom of the tub housing there should be a nipple where the clear hose connects onto.....follow the clear hose from the switch down to the bottom of the tub.........disconnect the clear hose on the bottom of the tub.....plugg the nipple with your finger.........gently blow into the hose with your mouth.......but make sure the water level in the tub is at least at half way full...and the washer is on and filling up with water ...after you blow into the hose the washer should agitate.......if it does agitate your water level switch is defective...connect hose back........get your model number and source for the switch.........
Apr 10, 2010 | Whirlpool Washing Machines
WHAT IS THE SIZE OF MY WHIRLPOOL WASHER? model number LXR9245EQ2
We have the same model. We plan to purchase a replacement washer, and tank size is a major factor.
Machine manuals are available at www.whirlpool.com. It's great Whirlpool has the docs available online, but there was no indication of tank volume for this model found in the manuals: Parts, User, Instructions.
I decided to figure it out by filling the washing machine tank manually counting the number gallons of water dumped in. I managed to dump in 23 gallons before risking overflow. I don't recommend this approach since the specified water level limit for the tank assembly may be lower than the perceived water level limit. This volume test was performed on a machine that's being disposed.
Google says 1 US gallon is equivalent to approximately 0.1337 cubic feet. Applying this ratio to the number of gallons poured in, the volume is 3.08 cubic feet. If 24 gallons, then 3.21 cubic feet.
I'm sure the tank is not 4.0 cubic feet since that would have required another 7 gallons of water, beyond the 23 already poured in, making a mess on the floor, and potentially wetting machine wiring and other hardware that should remain dry. Even if we account for the space occupied by the agitator, it's unlikely an additional 7 gallons of water could be added without significant overflow.
4.0 cubic feet is approximately 30 gallons.
We're going on the assumption our LXR9245EQ2 washer is a 3.2 CF machine.
Dec 07, 2009 | Whirlpool Washing Machines
Water will not stop when level is reached but starts next cycle
If the water will stop when you turn the washer off then the problem is the water level switch. It's a switch connected to a hose which goes between the inner and outer tub. You can blow on it and the water should cut off. The filling water puts pressure on the switch with the air in the hose.
If the water doesn't stop when you cut the washer off then the water inlet valve is probably stuck open. The water supply hoses on the back connect to the valves.
Aug 22, 2009 | Washing Machines
LST8244BQ0 Should I just get a new washer? Overflows with water, keeps on filling. Stops filling when you switch to rinse cycle from wash cycle though. Drains well. I may have overloaded when I was washing...
Simple fix. But you might need a tech. Sounds like your water level switch needs fixed or replaced. Most work on air pressure. (Huh? your saying? :) A tube (you can't see) runs down the verticle length of the tub. As the tub fills with water the air in the tube increases the air pressure within it. There is an air pressure switch on top of the tube and the "Washer Load Size" switch adjusts so that when the air pressure is correct (water level in the tub) meets the requirements of what you set it to, then it turns off the water inlet valve and starts the washing cycle.
If this "water level tube" gets disconected, it will not work. Also if it gets cracked (it is plastic) or gets plugged somehow, or if the switch fails, you wil have water, water everywhere.
Here is the manual online -
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=LST8244BQ0&siteCd=WHRCOM
Whirlpool's Toll Free number is number is: 866-698-2538
and thier customer service Web site is: http://www.whirlpool.com/custserv/index.jsp
Hope this helps - If so - Check "Fixya" below!
Len
Jul 26, 2009 | Whirlpool Washing Machines
Hi. My water level knob is very hard to turn and the water level is not correct when filling the washer. Any thoughts?
if it has been quite some time since you turned the knob it is possible that it is starting to sieze up, you may have to replace the switch behind the knob
May 09, 2009 | Whirlpool WTW5560SQ Top Load Washer
Washing Machines Logo
194 people viewed this question
Top Washing Machines Experts
