Question about Asko T711 Electric Dryer
I cannot find the part to order for my Asko T711 dryer.When running, it seems to be hot, but it takes a long time to draw out the moisture. It also does not shut off after the clothes are totally dry. IF there is a thermostat or control unit, i can replace it. I just cannot locate the repair manual only a user guide, which does not help. Any help would be appreciated. Thx.
  • 1 more comment
  • consultan350 Mar 28, 2011
    Thanks Macmarkus. I did clean the duct and the blower wheel. I think it might be a faulty moisture sensor, but I do not know where it is located or the part # so I can order it before I take the skin off to repair it. My email is - consultant@lconner.com
    No problem. Thx.
  • Asko Master
  • 2,605 Answers
Hello, Welcome to FixYa. I have a service manual I can send you via email, but I'd need you to post an email address as it is too large to post here. How is the air flow...it could be a clogged blower wheel or a faulty moisture sensor. The service manual will certainly help you locate & check those. Again let me know and we can move forward. Regards, Macmarkus :)
Posted on Mar 27, 2011
  • Mark MacDonald
    Mark MacDonald Mar 28, 2011
    Hello again,
    Thank you for the reply. You actually caught me away from my PC ( on my iphone ) but I will certainly send that "pdf" info asap. If you are alright with waiting I should have access to my PC in a couple of hours and email you for the Asko.
    Regards,
    Macmarkus :)
Asko T711 Dryer
Most often the top panel is the first to be removed, a couple screws in the back and then lift and slide forward. That normally gives access to view how the rest of the puzzle went together.I changed bearings on my Crosley and never did move the front cover. This might give you a place to start while waiting for a better answer.
Jan 06, 2014 | Asko Dryers
I have a T711 asko dryer. When I push the start button it makes the sound when the dryer has completed its cycle. There is a "signal" button that you can depress to let you know the dryer is finishe
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Nov 11, 2011 | Asko T711 Electric Dryer
The drum stopped turning on our Asko t700 dryer even though the dryer motor works fine so it runs and blows air but will not turn. Both of the fuses seem fine and as I say the motor and everything else is...
the belt is broken, here is a thread:
http://applianceguru.com/forum2/2043.html
here is a manual:
http://www.ajmadison.com/ajmadison/itemdocs/English-T711-721-731-761-781_UCG.pdf
Hope it helps Tim
Apr 25, 2011 | Asko T700 Electric Commercial Dryer
Where is the thermostatelocatedonthe asko t711 dryer
Welcome to FixYa.
To answer your question, it depends on which thermostat`s it is you`d like to know about.
Attached below is the location of the cycling thermostat`s and below that is the location of the reset-able safety thermostat. It is on the back wall under the black rubber cap I`m pointing at in the 2nd photo.
Cycling in front blower
Hi-limit reset-able thermostat.
Hope this answers your question, but let me know if you need anything else...I`ve got more info on the Asko washer, dryer, and dishwashers.
Thanks for choosing FixYa. Please take a moment to leave a testimony and rate the info I provided.
Good luck.
Regards,
Macmarkus :)
Sep 07, 2010 | Asko T711 Electric Dryer
No heat
heating coil... you can take the back vent off and feel if there is hot or cold air coming out. a heating coil is 30-60 dollars. You can call an repair service and parts place they can tell you the exact price
Aug 28, 2010 | Asko T711 Electric Dryer
My ASKO T702C dryer just stopped working. It starts but after 5 mins it just turns off. Any suggestions?
Try opening the bottom vent panel and pulling out the filter box (there are directions and handles)... hold the filter under running hot water for a while and you should see all this nasty stuff come out. Worked for me!
Jun 11, 2009 | Asko T711 Electric Dryer
Wrinkly clothes
Here are a few tips to combat this issue.
•Select a shorter drying time.
•Remove items while they still hold a slight amount of
moisture.
Remove items when cycle ends and fold or hang
immediately.
This will prevent wrinkles.
Feb 21, 2009 | Asko T711 Electric Dryer
Asko Dryer model T-701
you need to replace the motor you can replace the rear half of the motor but you can only buy a complete motor.this isnt a common problem but i have had it before.it broke because you need to grease the pin every 5 years or so.
Oct 24, 2008 | Asko T711 Electric Dryer
Asko T711 Electric Dryer Logo
83 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you an Asko Dryer Expert? Answer questions, earn points and help others
