Question about Astar LTV-32ASB 32 in. LCD Television
Blue light on front blinks but set will not come on at all
    Problem Solver:
  • 10 Answers
Hello your tv infront the intercate light blinking is mean your tv power supply is out, (defectived)
Any question, call me at 323-868-3303 or email me tietivan@yaoo.com
Thank you and good=luck 2 you.
Posted on May 25, 2011
WHY WON'T MY HITACHI PLASMA TV SHOW PICTURE OR SOUND? WHAT DOES THE BLUE LIGHT ON THE FRONT FLASHING 4 BLINKS MEAN?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Aug 31, 2016 | Hitachi Televison & Video
Why doesn't my neotv netgear remote no longer communicating with box?
What do the different Remote control front LED lights mean?
  • Blink blue color twice per second: Remote control has paired NeoTV PRIME and is trying to connect NeoTV PRIME.
  • Blink blue color once per second: Remote control is trying to pair the NeoTV PRIME.
  • Orange blinking: Remote control battery is low. Please replace a new set of AAA battery.
go to page 15 of the following document:
http://www.netgear.com/landing/stream/img/gtv-specs/GTV100_IG_25Oct2012.pdf
Sep 09, 2014 | Computers & Internet
Why is a blue light blinking on the front of my phone?
it lights up to tell ya when phones charging charged ringin etc.ya can change it in ya settings
Jan 01, 2014 | Samsung Galaxy Cell Phones
Phillips tv no pic no sound just flashing light
Its not going to be a do it yourself repair--likely a bad board or even boards--have a repair center (authorized for this brand) inspect it.
Just getting a set like this apart safely is tricky.
Apr 29, 2012 | Televison & Video
Why is the blue light on front blinking
My answer is based on the model number here-AV-56WP74 or similar--blue light blinking is shutdown to protect the power supply in the set.
A few questions you could answer:
before this happened was screen red (too much) or had colors skewed or a little 3d looking?
The most common issue on this set if that is convergence and it can easily escalate to where it shuts the set down and blue blinks constant.
There is a simple way to confirm or deny that issue--Got someone willing to try that? Set will be unplugged and entire front grill under screen removed to try it(I can tell you how and what to do)
If no skill at all--consult a shop--if want I will answer questions or comments you post on this page--(add a comment button)
SD TECH-
Apr 02, 2012 | JVC AV-56WP74 56" Rear Projection...
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
Screen turns blue and suddenly tv shuts off....red light on front blinking
The Blue CRT is the most likliest cause and will need replacement.You can verify by removing the Blue CRT drive board if the set powers up and stays on you will know the Blue CRT is causing the shutdown.
Feb 16, 2011 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57wv600 tv turns on shows picture then blinks blue a few times and then shuts off....stnadby light blinks 7 times...whats the problem
Its either blue tube or bad componet on blue CRT board hertes how to know disconnect Blue CRT board connect to neck of blue tube turn set on see what happens if set come on and plays then this lets you know if it is a problem with tube/video ic on crt board. If set shuts back off different problem.
Dec 25, 2008 | Sony KP-57WV600 57" Rear Projection...
My RCA HD50LPW175yx7 is blinling five(5) times and then shuts off
i have the same t.v. the owners manual says "if the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on.If the t.v. does'nt turn on after 5 minutes and the light blinks steadily for 1 minute , one of the following is possible: lamp door is open , lamp is dead , or the power supply within the t.v. needs service.
Nov 29, 2008 | RCA HD50LPW175 50" HDTV
Blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Sep 23, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Astar LTV-32ASB 32 in. LCD Television Logo
76 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
