Question about Buck Dodge Ram 1500 2002 Car Radio/stereo Wire Harness Plug
2002 dodge ram 1500. Door locks do not work, under hood light does not work, door ajar light comes on after I start driving and the radio shuts off as well. The radio plays and the door ajar light stays off until I put it in drive and start driving down the road. If I push down on the door lock button while in park, the radio shuts off and the door ajar light comes on. Not the iod fuse, already changed it, already disconnected battery. thank you for any info
3 Suggested Answers
97F350diesel
  • 1326 Answers
SOURCE: Radio just quit playing ... was fine Friday on the
If aftermarket check the fuse on the radio, if factory its a good chance your radio has gone bad
Posted on Nov 05, 2009
ZJLimited
  • 17970 Answers
SOURCE: Need to find out what
Fig. Cylinder head torque sequence-4.7L engine
Install the cylinder heads. Use new gaskets and tighten the bolts, in sequence, as follows:
  1. Step 1: Bolts 1-10 to 15 ft. lbs. (20 Nm)
  2. Step 2: Bolts 1-10 to 35 ft. lbs. (47 Nm)
  3. Step 3: Bolts 11-14 to 18 ft. lbs. (25 Nm)
  4. Step 4: Bolts 1-10 plus 1 / 4 (90 degree) turn
  5. Step 5: Bolts 11-14 to 19 ft. lbs. (26 Nm)
Hope this helps (remember to rate and comment this answer).
Posted on Sep 09, 2011
Where is the power door lock fuse?
look on the left or right hand side of where the door panel meets the side of the dash, may be a small finge rpull type door, fuses are behind it,, or check under the hood at the relay center box
press the helpful button and check links below
http://www.ramforumz.com/showthread.php?t=73846
Power Door Lock Problem DodgeForum com
Interior Fuse Box Location 1994 2002 Dodge Ram 2500 1997 Dodge Ram 2500 5...
Jan 30, 2016 | 1998 Dodge Ram 1500 4WD
2002 dodge ram 1500 door locks and radio wont work .
fuse under hood? or 30 amp fuse by drivers door maybe ?
Sep 30, 2011 | 2001 Dodge Ram 1500 Truck 2WD
I have a 2000 Dodge Ram 1500 EXTR CAB My A/C blows then I hear a door shut somewhere under the dash, and nothing but heat comes out, sometimes the door opens back up sometimes it stays closed for long...
check for a loose or damaged vacuum line that controls the blend door-it could be under the hood (look on the intake manifold) or under the passenger side of the dash-it might also be the climate control unit itself, either a leaky vacuum line or an electrical connector that is loose.
May 22, 2011 | 2000 Dodge Ram 1500 Truck
I have a 2002 dodge RAM 1500. Recently it started acting crazy. when I am in drive and press on the gas, the interior light flashes on and then off, the door ajar light comes on, the automatic locking...
i have seen this once before but it was the brake pedal that made everything go wacko, talk to the dealership near you, this has been a problem since the 98 model
Mar 28, 2011 | 2001 Dodge Ram 1500 Truck 2WD
My door ajar lights wont turn off.
I do not think it has anything to do with the door. I think you should put a scan tool on it and see what you pull for codes.
Please let me know.
Feb 08, 2010 | 2002 Dodge Ram 3500 Truck
Open door lights flashing turn key all gauges
this is the starter relay your battery is most likley very low or the starter is bad
Jan 06, 2010 | 2000 Dodge Ram 1500 Truck
2003 ram 5.7 electrical problem
run a status check on the pcm. sometimes those probs are in the computer. the loghts will come on when the remote is activated, and the door locks should lock automatically when you start to drive. if that doesn'tr happen, suspect a computer glitch.
Jul 20, 2009 | 2004 Dodge Ram 1500
2002 Dodge Ram 1500 power door locks keep blowing fuse
by process of elimination!
one door at a time so disconnect 3 & keep changing the active one till you find which one isnt working
then test its circuits ok
Cheers rob.
Jul 20, 2009 | Dodge Ram 1500 Cars & Trucks
Buck Dodge Ram 1500 2002 Car Radio/stereo Wire Harness Plug Logo
171 people viewed this question
Top Buck Car Audio & Video Experts
xxxxxx xxx
Libran Moreno
handygirl911
handygirl911
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
