Question about Starbucks Barista Burr Grinder
Starbucks EL60 coffee grinder: where can I find a new knob?
Did you find one? I need one also.
Posted on Aug 16, 2011
I got a saeco italia and the coffee tastes too light. how can i adjust it to make the coffee strong??
Hi
There are 2 knobs in the bean hopper. Turn the big knob to 8 and the small knob to the plus (+), then back one mark. If the grinder is already lower than 8 and the grinds look larger than coarse sugar you might have a seperated grinder.
Dec 21, 2010 | Starbucks Saeco Italia Digital Barista...
Grinder runs but will not accepts beans for grinding.
Hi Try turning the big knob up to 18 and the small knob down towards the minus. If that doesn't work your are going to have to disassemble the grinder and clean out all the passages. What is causing this to happen is your grind is too fine and the grinder is compacting the coffee in the passage. Once it is cleared, turn the grind down but higher than you had it before.
Nov 26, 2010 | Starbucks Saeco Italia Digital Barista...
My machine is getting the waste coffee stuck to the screen inside where it brews, it doesnt make pucks any more they are loose
Hi
Turn the + / - knob in the bean hopper to the + and then back 1 mark. Are the grounds coarse or fine? They should be like coarse sugar through your fingers. If they are very coarse that can be part of the problem. What is your setting on the big knob. It should be around 8 depending on your bean. Only turn the big knob down when the grinder is grinding. You can turn it up any time.
Nov 14, 2010 | Starbucks Saeco Italia Digital Barista...
Starbucks Barista Burr Grinder (Solis 166) motor does not run
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
Turn the grinder upside down
There are 4 slits on the outside edge.
Insert a screw driver into the **** and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
Dec 21, 2008 | Solis Maestro Electric Burr Grinder
Timer switch is not working stuck in the on postion
I just had the same problem. It's the knob itself. You have to extract the knob by pulling, gently, and squeezing it out. The plastic housing over the metal thing is cracked. I took some super glue and duct tape and wound it tightly around it and pushed it back it and it works.
Dec 13, 2008 | Starbucks Barista Burr Grinder
Brand New Incanto, Grinder Doesn't Work
If you look at the adjustment knob in the bean hopper, make sure it is in the middle i think it will be "8".
Make sure you not get any damp into the grinder.
Try to make 2-3 cup of coffee.
Let me know if i can help you more
Best regards
/Mirran
Nov 08, 2008 | Starbucks Saeco Italia Digital Barista...
Coffee Makers & Espresso Machines Logo
480 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
