Question about Gateway NV5207u Notebook
Gateway NV5207u will not power on when the power button is pressed. The Power light does not light up when the battery or AC power is plugged in. Can you help?
  • yattster Mar 27, 2011
    Unit power LED does not respond to any power source (power supply, ac adapter, new ac adapter). No indication that power is reaching the board. Not fans, leds or anything.
    Genius:
  • 1,288 Answers
Sounds like there is a serious fault in the motherboard. I'm assuming you checked that the AC adaptor is working ok? Check first that there is power to the adaptor and power out of the adaptor by ensuring the green led is on and not flashing, a flashing led indicates power is not making a circuit in the motherboard and therefore a faulty powerboard.
Posted on Mar 27, 2011
  • ladyragsdale Apr 17, 2011
    My ateway does the same thing it was the motherboard it had to be replaced it was under warenty
  • graeme ian hunter Apr 17, 2011
    As I suggested in my original post.. some people don't like bad news however, as evidenced by their "single thumb".. oh well....
I replaced the ac adapter on the motherboard of the Gateway NV5207u and now when I try to power it on, won't power on. battery light red
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
Mar 30, 2013 | Gateway NV5207u Notebook
Charger light goes out when plug in computer
it could be that the connection jack on the mainboard has been dislodged from the solder joint, common among Gateway comuters and HP units too. is the DC jack loose from the notebook ? if so thats the issue it seems. You will have to bring it to a computer person to resolder. if not and youc an do it yourslef, save money -- but be careful not to damage anything on the mainboard.
Jan 03, 2012 | Gateway NV5207u Notebook
I have a Gateway NV5207u and it will not boot up. It runs Windows 7 and I have been having a lot of problems with it getting internal errors, goes to blue screen with an error listed (hardware problem)...
Before you go that route, have you tried a hard restart? To do so, you need to disconnect the power cable to the unit, then, press and hold the power button for about 30 seconds, then, reconnect the power cord, and see if it will then power up. Good luck, because I know the pain of not having an operational computer.
May 02, 2017 | Gateway NV5207u Notebook
My Gateway M-6847 will not turn on. When I press the power button the wireless light and power button light just flashes quickly. Also the battery light in front stays lit while plugged in.
Hi
silly question sorry
but have you charged the battery or plugged the power cord into plug and switched on to try to charge the battery for a couple of hrs without using the laptop
Jun 23, 2011 | Gateway M-6847 Notebook PC
I can't get it to power on. The battery lite lights up but the computer itself won't turn on.
Please remove the Battery and connect the Computer to direct AC outlet. Also, check if the Power supply is working normally. If the same issue persists, then the service is required
Jun 30, 2010 | Gateway NV5207u Notebook
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Gateway MA7 (MX6955) Will not boot up, or power on. Battery and AC plugged in battery LED light flashes 4 times and nothing... battery in AC unplugged.. same thing... battery out, AC plugged in.. nothing,...
hold on i have a gateway here let me see if it does or not.nope mine works without battery i had to push the power button a couple times but it fired up.could be your MB
Oct 08, 2009 | Computers & Internet
Gateway Laptop M350WVN- not booting at all
it may need to be left on charge for a while...
when u first boot by pressing power wait for a minute or so and press and hold power button til shut down then try reboot..also try boot from disk....need to distinguish whether motherboard or software issue.
Feb 05, 2009 | Gateway Computers & Internet
Gateway MX6438 will not power on
if your battery is dead and your not able to use the adapter to keep it going, its probably a dead ac adapter. is the light where its connected ? light on the box (if it has one), the outlet you are plugged into have power to it ? try another plug
Dec 29, 2008 | Gateway MT6730 Notebook PC
Gateway NV5207u Notebook Logo
721 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
