Question about Electrolux Vacuums
I have the 50th jubilee electrolux model(1210)...it smells funny when I have it on and I quickly turn it off....what could it be?
  • 694 Answers
Unless the motor has been replaced at some point, a bad one is my guess. You can order a new motor from an Aerus Electrolux store and they will generally replace it just for the cost of the motor. One year warranty against defects, workmanship, and on the labor.
With potential other problems on a vacuum this age, you may be ahead buying a new one. Or even a newer used one. Aerus Electrolux still has new models available for less than $1200, and with a 5 year warranty. Still a terrific machine.
http://www.aerushome.com/storelocator/
Posted on Mar 27, 2011
Where can I find manual for Electrolux diamond jubilee shampoooer Model 1522
Try Googling (Electrolux)(1522)(manual) without parens.
Jan 07, 2018 | Electrolux Vacuums
Why does my 1521 overheats and turn off
Its probably full of dust and lint, and most likely has something wrapped around the motor shaft. Take it apart and inspect in and around the moving parts of the motor, impeller, shaft etc Best way if you are not too handy and poor memory. Either make a video of disassemble or detailed diagrams as you take it apart. It will make your life a lot easier when you re-assemble it!
Aug 30, 2014 | Electrolux Diamond Jubilee 1521 Vacuum...
Electrolux vacuum problems
could be a stratched belt that needs changing,smells like burnt rubber.Or the motor is overheating,check for any blocks in the hose or Power head.Hope this helps.Chris
Aug 11, 2014 | Electrolux Vacuums
My Electrolux Precision Brushroll Clean Bagless Upright Vacuum, EL8807A Won't Start. I Plug it in and turn it on and nothing ... no motor sound no suction, it has a burn smell. The brush will roll but the...
The burn smell means you should take it to a qualified Electrolux repair facility. It may be an electrical issue and could catch on fire if not repaired properly.
Oct 25, 2013 | Electrolux Vacuums
Electrolux Precision vacuum brushes stopped turning and a red light turned on
there's a reset button down on left side of powerhead in the black plastic at base that corrects the problem of that red light
Jan 12, 2013 | Electrolux Vacuums
I have a electrolux run shampooer Model B-8 A62612H how do i get the brushes off to clean
A quick twist counter-clockwise while pulling should do it. If not, contact an Aerus Electrolux store near you.
Nov 04, 2010 | Electrolux Vacuums
Panasonic MC-CL673 vacuum is not getting up to speed and smells
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar. This is causing the smell (burning rubber). I don't believe it is your motor. :-)
Jim
Nov 29, 2009 | Panasonic Vacuums
I am looking to buy a used electrolux vacuum cleaner. I have the choice between the ultralux, the marquise, the diamond jubilee, and the olympia. Which one is the best model? Which has the best...
The Ultralux is the newest of your list. The Olympia has the old type powernozzel that is rectangular. The rest have the new L shaped powernozzel and the brush is longer. As to the performance, the three newer vacuums should be the same. If the vacuums are used and not rebuilt, I would select the Ultralux. The Marquise had a motor issue when they came out and if the motor has not been changed I would stear clear of it. I changed 37 motors in one month under warranty. They did rectify the problem with the later models of the Ultralux.
Joe
Mar 13, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Vacuum shuts off and has a burnt smell
Try removing the drivebelt, and try running it to test like this. The brush bar will not turn, but it should function normally without smell at this point. If it doesn't, you may need a new motor as I think the brushes may have worn down - producing an electrical type burning smell.
If it runs fine without the belt attatched, then there is probably a build-up of hair or threads at each end of the roller stopping it turning freely. With the hoover off, check it turns freely and easily. A small metal nail file or similar is usually a good tool to clear it.
If the roller is stiff, the belt will not turn easily, and overheat on the motor spindle - causing the burning smell.
Jan 08, 2009 | Hoover Vacuums
Vacuums Logo
166 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
