Question about Echo Garden
ECHO SRM 210- I have removed the nylon string head and cannot find in the manual, or online, any way to attach a 22 tooth blade. How is the blade secured?
  • Anonymous Mar 21, 2014
    Need to know how to put blade adaptor on a echo srm 210 weedeater
  • 3,740 Answers
First off you have to have the blade conversion kit PN 99944200418 or 99944200418
Then you must install the kit that involves removing everything down to the angle drive mounting plate.
The blade conversion kit installation instructions are here:
http://www.echo-usa.com/pdf/documentation/99944200418%20422esf_070110.pdf
The conversion kit parts manual is here:
http://www.echo-usa.com/pdf/documentation/99944200415_011206.pdf
The users manual is here:
http://www.echo-usa.com/pdf/documentation/99944200411_101805.pdf
If by chance any of the links above do not work you can find them here: (except owners manual)
http://www.echo-usa.com/documentation.asp?Model=SRM-261T&lang=E&Type=ACC
Posted on Mar 27, 2011
  • sykomiko Mar 27, 2011
    Thank you for the quick response and informative answer. Excellent website!
Echo SRM-210 Boggs down when at full idle
Hi Bobbi Jo:
Here's a link that will get you the user manual.
http://lawnandgarden.manualsonline.com/manuals/mfg/echo/srm210.html?p=1
Page 24 details exhaust carbon removal, and Page 25 gives carb setup info.
Hope this help.
Cheers
Jun 22, 2016 | Echo Garden
How do I fix a echo srm 210 weedeater that starts but will only run a few seconds?
Try calling echo and ask for tech support or go online to get the phone # or check you tube to see if they have a video on it
Apr 05, 2016 | Echo Garden
I have a Echo Gas trimmer SRM-210 Rapid feeder dual line. I need to know how to remove the entire drum for the string spool? NOT how to re-string but how to replace entire head/spool, as if I was going to...
In your manual under section 12: Line Head Installation. You will do the opposite of what it says here. The key is to LOCK the gear drive so the flex-drive shaft won't turn WHEN you are removing the trimmer head. They use a special tool (maybe you have it). But a small-shafted Phillips screwdriver or the like can be put in the drive hole to lock the gearing up as well. Look for the hole in the upper plate and align with the notch in the drive housing and grasping the entire string head unit, remove it. Here is your manual, see Section 12
http://dl.owneriq.net/8/854215d5-44e4-4b5d-b773-77b331fd73b3.pdf
Jul 17, 2011 | Echo Rapid Loader, Trimmer Head
Could you please explain how I change from the nylon line trimming head to the metal cutting blade on my Echo brush cutter model SRM-22GES? Thanks for your help.
To change the head on the trimmer you will need to turn the trimmer upside down as if you were going to take the head off to restring it, spin the head and look for a slot in the side of the head when you see the slot, keep spinning until you see it line up with a hole in the metal piece the head attaches to. Stick a nail in the slot and hole and turn the head off the trimmer, if I remember correctly the head is backward thread.
Follow the steps backward for putting the brush blade head on the trimmer.
Apr 25, 2011 | Garden
How do I change the cutting line on my SRM 210 ? I do not have a manual.
You may be able to download an owners manual here as your model is a very popular one and they may have it.
http://www.manualsonline.com/
Stringing the head info should be in the manual.
Aug 29, 2010 | Echo Garden
Echo srm-225 string broke off inside of the spool. How to get it out?
I solved the problem myself. I found the manual online and followed the directions that were given. Having the manual helped because it allowed me to know how to open up the spool without damaging it.
Sep 30, 2009 | Echo Garden
Need Help Installing U-Turn Trimmer Head on Echo SRM-210
It is ridiculous, there are a bunch of bolts, and then a multi-fit brochure showing a grid of nonsense.
There are instructions on the inside of the package, however that is how to string the line.
Sep 19, 2009 | Echo Rapid Loader, Trimmer Head
Need to remove head from SRM 210 weed trimmer
I have the same model. Home Depot assembles their trimmers then sells them, so I didn't get the stuff that comes with it. A 3/16" punch works perfectly.
Aug 09, 2009 | Echo Rapid Loader, Trimmer Head
How can I remove Echo 230 SRM trimmer head?
Don't know for sure, but I found manual on amazon, Amazon com echo srm manual so take a look if you want. have a nice day
Jul 21, 2009 | Echo Rapid Loader, Trimmer Head
Open Questions:
Garden Logo
868 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
