Question about Microsoft Windows XP Professional for PC
Recently reformatted my laptop (Compac NC6000) and successfully reinstalled Windows XP Professional. Decided to update to SP3 and downloaded the first batch of critical updates sucessfully, but for some reason the next lot of updates would download but not install. I just keep getting a message "Could not install updates" with a list of the updates that were downloaded but could not be installed!
Thanks in advance,
Gomog
Please send me the error message in case you have any, please do let me know which updates you were unable to install( security updates or critical updates).
Click on the link below and run the file. REGISTER FILES
Run this file and open the internet explorer and try to perform the windows update again.
you will be successfully able to install the updates.
Posted on Sep 24, 2008
Did you try uninstalling the last batch of updates?
To see the updates under "Add or Remove Programs", you'll need to check the appropriate box at the top.
If uninstalling does not help, you may have to start over.
Possible approaches to avoid the same issue when starting over:
  • Don't use SP3, unless you know that you *need* it. Check Wikipedia to decide whether you need it.
  • Install OS with SP2 and all updates, only then apply SP3.
  • Don't install all updates at once. Install them in batches of, say, 10 a batch. If the same thing happens, you know which batch was responsible.
Posted on Aug 05, 2008
I cannot get rid of pceu virus on a windows xp pro fujitsu desktop because it has disabled safe mode and I do not have the windows xp cd to reinstall windows and the cd/dvd drive does not work .
Download the SP3 installation ISO. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en xp pro sp3 iso http://www.imgburn.com/ Download the iso also download the imageburn or
http://windows-xp-pro-startup-disk.soft32.com/ Bootable disk for XP Professional. The Windows XP start up disk allows computers without a bootable CD-ROM to perform a new installation of the operating system. Hope this helps.
Jan 21, 2013 | Fujitsu Computers & Internet
I need to reinstall SP2 over genuine XP reinstallation. This pack is now unavailable from Microsoft.
Windows XP SP3 comes separately with its own registration key. No previous versions are needed for a fresh install. Update packs are also available in many websites.
Nov 30, 2011 | Microsoft Windows XP Professional
It has service pack 3 installed. when i try and update it says i need service pack 3
Turn automatic updates on it will certify your SP3 and Windows copy then it will work again without the message. Something Microsoft has done recently.
Aug 12, 2011 | HP Compaq nc6000 Notebook
My system now window7 .iwant instaling window xp .but no awaiable boot iwant driver
You can download the latest version (sp3 2011) of windows xp from this link:
http://www.world4free.in/2011/02/windows-xp-sp3-2011-v-1102-full.html
After downloading, place a plane CD in the CD/DVD writer and then double click the downloaded file. Now the burning process will begin. After burning is successfully completed, you can use this CD as your boot disc. Follow the installation procedure as usual.
Hope this one solved your problem. If you have additional doubts, please come back to us.
Regards
Sunny.
P.S: If the solution is helpful, please accept the solution.
Jul 09, 2011 | Acer INTEL CELERON DUAL-CORE PROCESSOR...
HP Compaq nc6000 powers up and then down automatically
check first the power connector.. and be sure that you power not auto shut off. then instal again the os.. even this vista or xp don'st matter...
as long as you powere is good condition..
Jun 13, 2009 | HP Compaq nc6000 Notebook
Cannot reinstall Windows on my Hp Compaq nc6000
I know I just had the same problem today...when getting into the bios...try using a "multi-bay" boot and have the cd booted first then the hd...That's the only way mine worked to "trick" the system to boot from the cd...it took a few times of stalling after that but with frustration and regathering with patience, it finally worked...you might have problems with the devices not being recognized after it does load unless you have an easy driver set to install from cd...otherwise you might have to manually install them to make them operate correctly. *hint: using the device manager to see any '?s' and reinstall drivers helped me*
Feb 05, 2009 | HP Compaq nc6000 Notebook
Is there a way how to revert back the SP3 to SP2 for windows XP without reformatting the computer?
you can try by reinstalling the software again, if the problem is not solved then you have to uninstall the sp3 and stick to sp2
Jun 17, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional for PC Logo
139 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
