Question about PfaFF Creative 7570
My 7510 says "adjusting pattern" 248 when I turn
    Scholar:
  • 89 Answers
I had this problem a few weeks ago. A new baseplate fixed it. You will need to take it to a Pfaff repair shop
Posted on Mar 28, 2011
I have a pfaff creative 7510. Which foot is the zipper foot and how do I change the needle position?
First here is a copy of the manual. PFAFF Creative 7510 Instruction Manual
Pg 96 shows a photo of the zipper foot, and directions on how to use it. I hope this helps.
Mar 02, 2017 | PfaFF Sewing Machines
I have a Singer Curvy 8780. All I want to do is sew a straight stitch. What are the settings?
You'll need stitch pattern 01 in the first group after you press the utility stitch button (top button on the left of the 4 way arrow keys). Press button A (the left most up-arrow below the LCD screen). Use buttons B (move left) & C (move right) to select the needle position and D (shorter) & E (longer) to adjust the stitch length. E is the right-hand button in the group. Start with the tension set to Auto and adjust as needed based on your fabric and thread. For normal straight seams, start with the default settings.
Singer has the manual for the Curvy 8780 on the product site: http://www.singerco.com/products/1545/8780-curvy#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/089a99d1802347d9441d83e8a591e6d0db17b80c.pdf . See page 30 for the stitch pattern; page 40 starts a longer discussion of straight stitching.
I hope this helps.
May 25, 2016 | Singer Sewing Machines
My sewing machine will not change patterns. stays on a pattern i do not want. need it on straight stitch. is there a part i can order for this problem?
Though I am not familiar with your modern Euro-Pro machine, some of the general advice I would give for the same problem on vintage "mechanical" machines may very well also apply to the newer "plastic" machines if the problem is mechanical and not electronic. If it is a mechanical problem, like the Stitch-Selector Knob being loose, out of adjustment or broken, or some thing in the mechanical linkage gone wrong, then you may be able to fix it yourself.
(1) Open the machine to access the inside of the top portion of the machine. This may be difficut on a newer machine.
(2) Find the CAM stack (those round disk-shaped Cams with the bumps around the outside edge). These control the stitch pattern, by controlling the needle swing-arm movement.
(3) Observe how the Stitch selection knob selects the built-in disk Cams.
Plan A: Jiggle the knob and follow the activation chain to the problem. If you can locate the exact point of the problem and re-adjust it, you are home free; if not, go to the next Plan.
Plan B: Manually change the Cam selection to Straight-Stitch (if that is what you want at this time). To do this, mimic what the knob mechanism does, or is trying to do. If that is not evident, then turn and/or lift-or-lower the selector or follow-finger, so it rides on a Cam that makes the kind of stitch you want. Sometimes a Spring that holds the follow-finger along the Cam edge comes loose, and you may have to devise a way to reset it so it holds the finger along the Cam edge. Also jiggle the Cam and linkages, to see just what each one does. It is most likely an adjustment and not a part that is needed (of course, unless a gear is striped or broken). Be sure that turning the Stitch-Selection Knob fully activates the chain of moving parts to make a change at the Cam stack. Find the brake in that chain of movements and you have found where the problem is.
Plan C: If possible, find a similar machine (or clear diagram/photo), and compare the knob movements and the linkage path to the Cam stack. Make yours like the model that works, and you have usually solved the problem.
Plan D: If you cannot solve this with these general instructions, maybe someone you know (hopefully sooner than later) with a high mechanical aptitude can resolve your Stitch-Selector Knob "Disconnect" malfunction.
Good Luck, and May God Bless Your Sewing. -- Amender.
Oct 23, 2014 | Euro-Pro Sewing Machines
Circuit board?
Yes, and probably No
Take it for evaluation and quote
Mar 14, 2014 | PfaFF Sewing Machines
Top thread bunches
try changing the needle--use a needle according to the fabric
being sewed
if thin fabric is being sewed try using a stablizer
rethread the machine top and bobbin--use every thread guide
make sure the bobbin is inserted correctly and turned correctly
in the bobbin case
also try adjusting the top thread tension just a little
Oct 23, 2012 | Singer 2950 Mechanical Sewing Machine
Straight stitch has peaks
Check your stitch pattern because you most likely have machine set to perform a blind stitch. chane your pattern setting to desired stitch and make sure you use appropriate foot attachment for the results you want. jimmy
Apr 03, 2012 | Brother XR-65t Mechanical Sewing Machine
My Elna Super won't sew zig zag or any other stitch except straight. What do I do?
Change the needle first in case it is faulty, if it is sewing straight stitch perfectly then you need to check the pattern camstack on top of the machine to see if there is a split in it
Aug 28, 2011 | Sewing Machines
How do I make a "space" in between the lettering. How do I enlarge to do stippling.
with the lettering mode, there should be a code number you program in for each letter, number and for a space as well.
Stippling is usually done by free motion stitching with a special foot so its not actually a stitch pattern, just a straight stitch that you form into the stippled pattern by moving the item as it is stitched.
Jul 20, 2011 | Elna 7200 Computerized Sewing Machine
Inspiration 4205 stitch length won't change
Are you certain that the pattern selector is set for straight stitch and not buttonhole?
Turn the handwheel so that the needle is up and the take-up lever is in it's highest position. Then turn the pattern selector knob through all of the patterns back and forth a few times. Finally, select straight stitch and see if the length works. If not, need to take it to a repair person to determine the course of action.
Feb 21, 2010 | Singer Inspiration 4206
Sewing Machines Logo
80 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
