Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Washer will not drain. tried to cycle on spin, rinse and regular wash. Still will not drain and we can't unlock the door.
  • 822 Answers
Move machine to outside door. let drain hose hang outside. this will allow most of the water to flow out............the pump may be blocked.................simple things like a small coin will block them........have to open the pump to check........do it near back door if poss as there will still be water inside machine...............
cheers
Posted on Mar 27, 2011
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
I have been getting the Sd code and then F21 code during regular wash. I followed directions cleaning out white filter on bottom of machine and it did not help. So I followed directions for resetting the...
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
need to replace the part but dont try it if you dont have idea how to do.
call the technician for your safety and not to waste money.
Oct 30, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
57 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
