Question about Teac Audio Players & Recorders
Need capstan belt for Teac A 650 cassette deck
  • 30 Answers
You can get a belt kit (3 belts) here: http://tinyurl.com/4o4pz98
Posted on Mar 27, 2011
You also may be able to get them from TEAC of America in
Montebello, CA.
Posted on Mar 18, 2012
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
The left side of New W-890R cassette deck plays at triple time. Right side plays normal. Tried to adjust with Pitch control but not the answer.
The transistor in the servo capstan motor is probably shorted- this happen now and then and you need a new Capstan motor. The question is most dual cassette decks are not worth the repair.
If the adjustment make no difference then that is likely the problem.
Sep 30, 2013 | Teac Audio Players & Recorders
How to replace the belts in a Teac A300 cassette deck
The mechanism needs to be taken apart sufficient to get to the flywheel and capstan motor- this usually entails taking the metal motor bracket off the back. It is not that difficult once you have done one. I may have replaced 50 to 100 of them at Teac in Chicago. Also oil the capstan bearing when changing a belt.
Aug 08, 2013 | Teac Audio Players & Recorders
Looking for rubber belts replacement for teac v8030s
Look on the Marrs Comunications web site and order the kit for the unit.
Apr 12, 2013 | Teac V-8030 Dual Cassette Deck
Thaks for helping. My tape deck door has suddenly stopped working. the tape is inside and when i turn on the wpower there is a clicking sound. it is a TEAC AD-500 CD player/reverse cassete deck
Without physically looking at the cassette deck myself, I cannot be 100% sure the tape is wrapped around the pinch roller and capstan. The capstan is the chrome rod which the rubber pinch roller pushes to regulate the speed of the tape moving across the head. However it is approximately a 90% chance the take up reel for the tape stopped working from a bad tape or a loose belt which drives the tape take up reel. The clicking sounds like it could be the auto reverse solenoid because it thinks the tape has reached the end of play. The fun part is to remove the tape which you may have to disassemble the front panel if you cannot gain access to the tape from the top or bottom. You will need to cut the tape and remove it from the capstan and pinch roller to open the cassette door. Sometimes you can remove the capstan to free the tape. Once you have cleaned all the tape out of the unit make sure the belt for the take-up is good. If it is glazed, cracked, loose or broken order a belt. Clean all the pulleys and capstan and replace the belt. Your unit should be functional after the above procedure.
Jul 14, 2011 | Teac R-H300 Dual Cassette Deck
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
I need a capstan drive belt for a TEAC 3440 reel to reel recorder. Wherr can I find one?
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
Oct 24, 2010 | Teac Audio Players & Recorders
Where can I buy a Capstan drive belt for a Teac A-4010 tape recorder??
Go to a consumer electronics repair shop, preferably an old mom&pop op and they will have what you need. If not they can order it for you when they do stocking and save you shipping money from any internet company. I used to work at one is how I know. Have a good one
Aug 07, 2009 | Teac Audio Players & Recorders
DC Motor turning continously in Cassette Deck
yes this is normal. the deck utilises what is called a rolling transport and the motor runs continiously to allow for mechanical cam engaged functions to work.
Dec 08, 2007 | Audio Players & Recorders
180 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
