Question about Sunfire Cinema Grand 200 Five 5-Channel Amplifier
My Sunfire Cinema Grand used to be working fine, and I stored it away but recently I dusted it off to use. All channels are working for except for the Front Right. Both the Voltage and Current Source sources are yielding a really delicate crackling sound in the speakers. I tried switching cables and inputs around and the cables and inputs work fine on the rear channels amp hookups if I hook it up that way. I checked the fuses and seem to be fine. Not sure what is going on and any help is appreciated!
  • 3 Answers
Crackling is not good. Sounds like it needs to be serviced if all of the connecting cables are in good working order. It can be repaired by Rita's Vintage Audio in WA state. They are expensive but good.
Posted on Mar 30, 2011
I need a face plate for a Sunfire Cinema Grand Signature
http://www.vintagehifipgh.com/index.php?main_page=index&cPath=23&
zenid=4vc1pf0puaqd1lrqkh7grkkr61
try this, they have several types...meder's tv service
Sep 10, 2012 | Sunfire Cinema Grand Signature Series II...
Hello all...I have a series 1 Cinema Grand 200/5 and have a slight HUM on my left channel (front and rear). The signal is from Sunfire TGP5. I have isolated the amp altogether with only speaker connections...
maybe a coupling or dc filter has gone bad, unpolarised ceramic or any other type, usually disc type or surface mounted. they are connected in series on the audio line. one easy way to find out is test the capacitors whether they are shorted (the ones on the left channel). or u can shift filter capacitors left to right one by one to find out the culprit.
Mar 08, 2010 | Sunfire Cinema Grand 200 Five 5-Channel...
Was working fine. started burning ac line fuses and noticed a little smoke. I found a bad light switch going to the ac outlet it was plugged into, which I think has caused this whole problem. removed the...
u have a shorted primary power supply unit on your amp. for linear supply check diodes and capacitors. for smps chek switching transistor or any other switching component. if u have no idea get it repaired by a tech.
Jan 30, 2010 | Sunfire Cinema Grand 200 Five 5-Channel...
Amplification
You need to now the RMS for a true capacity of your speakers and your amp.
I would say you are OK, with a margin, but if you turn the amp to max and blow the speakers, please dont call me.
Sep 30, 2009 | Sunfire Cinema Grand Signature 400 seven...
Loud static noise on power up.
slow down the volume before you turn on the Amplifier.
Jun 29, 2009 | Sunfire Cinema Grand 200 Five 5-Channel...
Microphone troubles
Contact the Sunfire tech folks . They've responded quickly for me.
Probably not in the power amp. It's whatever youre plugging the MIC into.
Jan 03, 2009 | Sunfire Cinema Grand Signature 400 seven...
JVC LT 43E488 LCD HD TV cable box doesn't get local channels
boomergal, do you have satelite cable or directv or dish?
Dec 12, 2008 | JVC AV-36D303 36" TV
Tempremental playing dvds
In response to your jvc-a75r DVD player, sometimes the solution might be less complex than it may appear. Had the same problem with my Samsung s321,the machine refused to read DVD's but would play CD's no problem. Simply opened up the cover(usually)4-6 small screws, and found my dog's hair inside of the player covering the laser eye.Electrostatic ionization attracts dust,etc. into the player remarkably well sometimes. Carefully used a cotton swap to remove debri. PLayerworked fine afterwards ...Good luck!
Feb 27, 2007 | JVC TH-A75R System
Sunfire Cinema Grand 200 Five 5-Channel Amplifier Logo
201 people viewed this question
Top Sunfire Audio Players & Recorders Experts
shaun taylor
woodzowl307
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
