Question about Dryers
Dryer shuts off before clothes are dry.Ireplaced the heaating element earlier and every thing was fine the cause for the element burning out was due to a plugged frozen shut outside duct door.I cleaned and replaced duct and door onthe outside of house.Could limit swithes now be bad ?
    Sergeant:
    Champion:
  • 202 Answers
Hi... yes you have a bad hi-limit .. No why of testing it
Posted on Mar 28, 2011
Kenmore model 90 dryer electric will dry the clothes takes a long time. Leaves the floor surrounding the dryer damp actually wet just not puddled
Are the clothes wet AND hot? If so - check the exhaust / vent hose for kinks or obstructions. That includes the cap / flap on the outside of the house.
If the clothes are wet AND cold, then the electric heating element isn't heating likely due to a broken or poor electrical connection, burned out heating element, defective thermostat, etc..
Jul 14, 2015 | Kenmore Dryers
Clothes not dry when dryer shuts off
First turn off your breakers, then back on. Next check the wiring at the back of the dryer. You could have wires burned in two. You may next have an element that is burned out. Your relay switch underneath the top could be bad. To check it , bypass it by taping the two wires coming off it together. If it works, then you will know it is the relay .
Mar 01, 2013 | Fisher and Paykel DEGX2 Dryer
Dryer only shuts off when door is open
test the push button for open and faulty .However see this causes too.
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Sep 27, 2012 | Frigidaire Dryers
Dryer takes a long time to dry
there is no truth to the fact that dryer elements start to burn out there fore it takes longer to dry cloths the only reason a dryer will take longer to dry cloths is due to lint build up within the unit take the back off and vacume all the old lint out and around the heating element and it will work like new
merry christmas
Dec 21, 2010 | Maytag Dryers
NO Heat ,when in Drying Cycle. Drying cycle works, but with no heat.Does not dry clothes.
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things: Mainly Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 08, 2010 | Malber WD1000 Front Load Washer/Dryer
I have a Maytag Atlantis dryer with intellidry sensor. it will not heat up enough to dry clothes - it just is slightly warm. The sensor always says "damp"
Hi
Thanks for using FixYa. No Heat issue in dryer is usually caused due to three things - thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in plastic housing. If that’s fine then the Heating Element should be checked. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 14, 2010 | Dryers
We bought a used motorhome with a Splendide 2100 w/d combo. It does not dry the clothes, but washes fine. There was no manual on this appliance, so don't know how to find out the problem. Can you help?...
Your heating element could be out. This could be just a bad element or if you don't hear the fan come in the the dry cycle, the fan probably failed and caused the element to burn out. If your clothes are getting warm but not drying completely then you need to check your exhaust hose and make sure it is not clogged with lint.
Jul 13, 2009 | Splendide 2100 Vented Washer-Dryer
No heat does not dry clothes worked earlier today
Your problem could be one of three things.
1. Check your lint filter, hose, and vent to make certain it has not gotten clogged or crimped
2. The heating element could be burned out or a connection may be loose
3. The timer may be damaged.
Check these things and, when you find the problem, come back for the solution.
Best of luck!
Jun 18, 2009 | Kenmore Dryers
Clothes not drying in condenser tumbler dryer
Sounds like your heating element is burned out (acually burned threw) I can walk threw it with you if you like.First find a replacement element.Everytime you turn it on the element gets weak from contraction and expansion.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 16, 2009 | Miele Novotronic T220 Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
Top Dryers Experts
