Question about Acer Aspire 5600 Series 5630-6951 Laptop
How to do fix a seagate hard drive if you cant reboot your hard drive?
  • 157 Answers
Seagate hard drives are usually covered by warranty ranginf from 3 - 5 years.
Go to this website http://support.seagate.com/customer/warranty_validation.jsp and enter the serial number of ur hard drive to see if th warranty is still valid. Then RMA it and theyll either repair it or send you a new one
Cheers
JigSaw xo
Posted on Aug 04, 2008
  • Anonymous Aug 04, 2008
    Are u meaning to say that the hard drive is faulty (making clicking sounds) or that their is no OS installed but was previously their
  • 3,940 Answers
Boot to the XP CD (Or Vista DVD) and attempt a repair of the OS. If that fails, then try a clean installation of the OS with a full format
SOURCE:
Hi I have a Seagate Barracuda ST2000DM001 2TB 7200 RPM 64MB Cache.It runs fine for a bit then it just diconnect itself,so you have to scan for hardware or you have to reboot the system.Is there a fix for...
Test your HDD (Hard Disk Drive): go HERE, click Downloads and download Seagate Seatools for DOS (free). Burn the ISO to a CD, set your 1st boot device = CD drive and reboot with the disk in the drive. When the tester loads, choose the Quick Test in the upper left corner of the screen. It takes 5-10 minutes and will give you a pass or fail. If it tells your that SMART has tripped, or gives a fail notice, your drive is failing. You should have a warranty on that drive with Seagate.
If the drive passes as good, change your data cable. I have seen bad cables cause problems. Also check the power cable.
If you still have problems, enter Administrative Tools\Disk Management. Find your drive, Right click on it, and click "Mark Partition as Active".
If still no joy, try changing the SATA port on the mother board that your drive is plugged in to.
If still no joy, contact Seagate customer help, they are very good.
Oct 08, 2013 | Seagate Barracuda 7200.10 / 500GB / 7200 /...
I cant find the installer for Seagate Expansion External Drive - hard drive - 500 GB, so i cant install this
Check with Seagates Customer support.
Should be an installer in their drivers section.
Possibly locate installer at www.driverguide.com
Jun 22, 2011 | Seagate FreeAgent Pro 500GB External USB...
My seagate 1TB external hard disk (the little compact one) cant be read anymore. Was working fine a couple of days ago. The lights on top are flashing constantly. After the drive is plugged into the...
Right click "My Computer" >properties> hardware> device manager. Expand "disk drives". Right click your seagate drive and click uninstall. Reboot your computer; the drive should automatically be reinstalled.
Feb 10, 2011 | Seagate FreeAgent Pro 1TB External USB...
How to know what is the problem of my hard drive?my hard drive is not clicking..but my computer cant read it,my computer cant format it....but the bios can detect it.....how to if it???
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 22, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
After Seagate device not recognized, all flash drives gave troubl
even tho you have AV software installed , I wouldn't write it off so easily. Download and run Malwarebytes from
www.malwarebytes.org
and you may be surprised how ineffective AV software can be some times.
Don't forget to rate the advice!
http://www.aa1consulting.com
Jul 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate hard drive will not power up
You have to be running NT, XP or Vista to access the drive. I take the power cable out, then plug it back in. Or try rebooting with the hard drive plugged in. Also purchase a USB Extension port so you can unplug the USB when not in use to stave off overheating. Go to Seagate and download Seatools. Also Download the source code for the drive while you are there.
Jan 27, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Connecting my Seagate 500GB USB drive reboots PC continuously.
update the firmware from seagate official,sir,any problem u can contact with me,thanks [email protected]
Nov 09, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate hard drive
Is this internal or external drive?
Jul 19, 2007 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
Power indication light flashing
Hi, you may want to try connecting it by USB if you're currently using firewire or the other way around and see if it works. If this fails, you are probably better off using diagnostics by Seagate @ http://www.seagate.com/ww/v/index.jsp?vgnextoid=7f4e19e0babfd010VgnVCM100000dd04090aRCRD&locale=en-US#. Try to use the Troubleshooting or FAQ or if you feel comfortable using their utilities, download SeaTools. Hope this be of help to you. Good luck.
Apr 23, 2007 | Seagate 300GB Pushbutton Backup External...
Acer Aspire 5600 Series 5630-6951 Laptop Logo
112 people viewed this question
Ekse
Alun Cox
