Question about Bosch Nexxt WTMC 3300 Electric Dryer
My Bosch Dryer WTMC300us/01 is making a rubbing noise with or without items in the dyer. And it "smells" hot. What's wrong and can I fix it?
  • Bosch Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Mar 27, 2011
GE DPXH46GA6CC gas dryer makes large humming noise in heat cycles and burning smell
Two things are likely going on here,1- something is dragging down your motor check for a twist in the belt, idler pulley bad, belt installed wrong or wrong belt. Also check your front drum felt and glides if the felt is bunched up that will drag down the motor. Now the smell you probably have some felt or lint in the burner clean it carefully you do not want to damage your igniter.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Aug 04, 2013 | GE Dryers
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
Warning signal "linter filter" comes on and dryer
You don't have very much information here to give you a better diagnosis, like the model or the error code, but I'll take a shot at it. If you're thinking that the flashing list filter light is the error code you can relax. The lint filter light ALWAYS flashes at the end of a cycle or before you hit the start button to begin a cycle. This is just a reminder to check the filter.
If your dyer is displaying an E:01 code this indicates blockage in the venting system. Do the simple thing 1st. wash your lint filter with some dish soap and running water, lightly scrubbing it with your finger tips. After rinsing clean pat the filter dry and re install it in the dryer. While you have the filter out look down in the filter holder area and see if you have lint built up there. They make brushes for cleaning this area or you can use a vacuum cleaner attachment to reach in there and **** out the lint.
If you still have an E:01 error after doing all this you may need to have your house vent pipe cleaned. But before you do this check your vent hood where the dyer vent exhausts out of the house. If it's obstructed you found your problem
Nov 27, 2010 | Bosch Nexxt 500 Dryer
Dyer making noise
maybe there is a dust or its full of clothes!
Jul 22, 2010 | Maytag MDG2706A Gas Dryer
Dryer rotates and drys well, but makes a noise when reversing rotation. Makes more noise at the beginning of use, then subsides. What could be wrong? Belt, bearings? Can I fix or do I need an expert?
heatman101
fsjhgf
Nov 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
I have a Kenmore gas dyer that has developed a burning smell
check vent line,either check outside to see if flapper is blowing open or disconnect vent line from back of dryer and see if it helps.if not there are two thermostats Number: 660036 Substitution: 279048 and
Number: 3387134 ,this one is on blower wheel housing and the other is in the back,take back wall off and you'll see it on right hand side on heater vent duct
Nov 03, 2009 | Kenmore Dryers
When dyer runs it makes a squealling noise like abad bearing>
Could be felt pads and nylon glides on the front drum support are deteriorated.
Could be a sticky build up on the rear drum rollers.
Could be a worn belt tension roller.
Unplug the dryer.
Remove the front panel.
Remove the front drum support.
Remove the belt and drum
Inspect the items listed above.
Replace as needed.
Mar 11, 2009 | Maytag Dryers
Dyer was grinding, then won't run
Sounds to me like you motor has froze up. Is there any smell coming from the dryer? The fuse would not cause this. A fuse would make the dryer do nothing when you hit the start button.
Nov 21, 2008 | Roper REX4634KQ Electric Dryer
Brand new Dryer with loud noise and hot
contact bosch for factory service on the unit
May 10, 2008 | Bosch Nexxt WTMC 6300 Electric Dryer
Bosch dryer
I had this problem for an axxis condensation WTL5410.
When starting dryer ligghts on front would cycle through normally as if dryer were running but dryer would not turn or get hot.
The problem was the door switch.  Push in the door switch activator on the bottom right of the dryer.  Push it hard a few times and try the dyer again.
doesnt sound like a great solution - but after 150$ and 2 service calls - it was what fixed it for us.
Jan 14, 2008 | Bosch Axxis WTL 6003 Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
207 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
