Question about Hotpoint Aquarius WMA56 Front Load Washer
MY HOTPOINT AQURAIUS WMA58 IS NOT DRAINING WAT CAN THE PROBLEM BE
    President:
  • 662 Answers
The solenoid in your drain valve has stuck closed or otherwise failed.
OR: the discharge hose has clogged or kinked.
Check;
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
Posted on Mar 27, 2011
Hotpoint wma58 stopped spinning
unplug it for a hour plug back in see if it resets it self
Apr 05, 2014 | Hotpoint WMA58 Front Load Washer
My washing machine doesn't want to fast spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 23, 2011 | Hotpoint WMA58 Front Load Washer
Hotpoint WMA58 working but will not spin - drum rotates but will not speed up.
It sounds like your belt is loose and needs to be replaced..
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Apr 12, 2010 | Hotpoint WMA58 Front Load Washer
Where can I get a wiring diagram for wma58
Here's the user's manual....it should have the wiring included. Good Luck
Aug 11, 2009 | Hotpoint WMA58 Front Load Washer
Is it possible to change bearing on a Hotpoint Aquarius WMA58? and if yes, can i do it my self? thx
You can do it your self, but it is a very involved repair, and I would not recommend that you attemt it, unless you are conversent with washing machines, it involves a complete strip down.
Please rate my solution.
Thanks.
Aug 05, 2009 | Hotpoint WMA58 Front Load Washer
My Hotpoint WMA58 washing machine is not heating the water so the cloths are only getting washed in cold water. Will this be the heater element that has gone? If so how do you change it.
We had this problem & called our repair man in. We had accidentally knocked the 'Variable Temperature' dial down too low. It should ALWAYS be set to max (95). The programmer will still sort out the correct temperatures for the different programmes, such as cold wash, but setting that to whatever temperature means that that is the max it will ever reach, Since then, we have not had that problem again.
Apr 02, 2009 | Hotpoint WMA58 Front Load Washer
Model wma58 as soon as the machine finishes it wash cyle and is to empty water gushes from them soap dispenser area .Is there a blockage causing this fault.
Probably blocked filter, remove lower rear cover, locate and remove large black hose on bottom of drum, remove and clean filter inside hose.
Thanks.
Mar 05, 2009 | Hotpoint WMA58 Front Load Washer
Hotpoint aquarius WMA58 spinning but not draining away all the water
Suggest you check pump filter.
you will find it located at the rear right side of the m/c.
Remove lower rear panel, there you will see a large black hose, remove securing clip, and detach hose, the filter is located inside, remove and clean, make sure you put everything back in the same order you took it off.
This should solve your prob. Make sure the drain hose is not clogged and the outlet is clear also.
Plz rate my solution.
Thanks.
Dec 21, 2008 | Washing Machines
Hotpoint WMA 58 not draining
I would check pump to make sure its not blocked with object.
Jan 05, 2008 | Hotpoint WMA58 Front Load Washer
Hotpoint Aquarius WMA56 Front Load Washer Logo
103 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
