SOURCE: remove siemens washing machine motor
You probably need to lever the motor back, as it is probably held in place on the motor mounts.
SOURCE: SIEMENS XLM1400 WASHING MACHINE DOES NOT SPIN
siemens xlm 1400 washing machine fills with water but wont wash
SOURCE: my siemens washing machine S14.39 keeps stopping a...
Hi
It is your pump that is failing / bolked with hair and treds behind the impeller. The pump is not the best design as ther can enter smal treds and hair behind the impeller into the paking ring (seal). There is only one sollution that help - change the pump. Can be don from the fron of the mashine. Only one screw on the right side has to be removed to remove the plastig cover and the one screw to losen the pump.
SOURCE: I have a Maytag neptune washing machine
yes you can buy the bearing to put in. it is by no means easy. they make a tool to inst. the bearing. it cost a arm and a leg buy tho. you may also find if you do take it apart that the shaft that rides in the bearing may be bad. that shaft is part of the inner tub. and that is way more then you want to put into the unit to repair it.
SOURCE: siemens washing machine feature "speedperfect
Methinks you could do with a manual- for now and later!
Now- unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing, or supporting, any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
