Question about Kenwood Blenders
My kenwood blender BL350 needs a new goblet drive coupling as it has warn out. The problem I can not unsecure this part, any ideas how I can do this?
3 Suggested Answers
SOURCE: can't get drive coupling off bosch unversal blender blade fixture
what you need to do is hold the blades with a towel to protect your hand, then, use a visegrips needle nose to grab the coupling (pushing the guard down) and twist it loose. It may be very tight, when I loosened mine, the plastic portion of the coupling pulled off leaving the metal "nut" tight to the shaft. Either way, remove the coupling/nut in the standard "lefty loosey" direction. Many thanks to the people at pleasanthillgrain.com for walking me through the process. Blessings to you.
Posted on Jun 01, 2009
  • 29 Answers
SOURCE: broken glass goblet
This place has spare parts in the U.S.
http://www.abtecparts.com/index.htm
They deliver worldwide. I am in Australia and just ordered the rubber ring and on the list there was the glass jug.
Posted on Jun 30, 2010
Do you have a instruction manual for a Kenwood Smothie maker, modle no SB256. Thankyou
could you tell me how to remove the drive coupling, from a kenwood sb300 smoothy pro ,please.
Feb 16, 2011 | Kenwood SB206 Smoothie Pro 3Speed Blender
Glass goblet/bowl for liquidiser
Normally stocked here: http://kitchenaidblenders.co.uk/Home/tabid/36/c/KitchenAid-Blender-Spares/CategoryID/6/Default.aspx
out of sotokc at present, expecting more by 5th Feb
Jan 02, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Broken glass goblet
Nov 02, 2009 | Krups Blenders
Can't get drive coupling off bosch unversal blender blade fixture
Mar 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
The blender coupling on my oster snapped in half. I have the replacement part already I just cannot figure out how to get the broken coupling off the base of the motor. I also got a replacement square...
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off" by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
Jul 11, 2008 | Oster 465 Work Top Blender
Back to Basic Smoothie Freeze Bades don't rotate
check to see if you can move the blades by rotating the shaft on the bottom of the goblet, sounds like you need a new blade assembly.
you can order the part from their website:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3699&secid=53&linkon=category&linkid=91
Jun 02, 2008 | Back to Basics 600 Smoothie Plus Work Top...
Blenders Logo
Top Kenwood Blenders Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve
Are you a Kenwood Blender Expert? Answer questions, earn points and help others
