Question about Oregon Cutting Systems Chain Saw Cutting Chains, 16"
What is the gas ratio to mix for a homelite chain saw model # ut10901A
  • 710 Answers
The ratio is 50:1
Happy sawing!
Thanks, if you appreciated this help, please place a vote for me.
Thanks,
Handie Andie
Posted on Mar 27, 2011
    President:
  • 1,489 Answers
50 parts gas to 1 part oil.
Charlie
  • sooterjay Mar 27, 2011
    is that a gallon of gas to what oz of oil
  • Samuel Charles Spriggs Mar 27, 2011
    A gallon of gas is 128 ounces.
    A 50 : 1 ratio would be 2.5 ounces of oil to 1 gallon of gas.
    Charlie
What is the correct gas mix ratio for a Homelite Pro 20" model #4620C 46cc
50:1 ratio to a gallon of gas. Non ethanol if you can find and a octane rating over 87
Dec 30, 2014 | Homelite Garden
What is the oil to gas ratio for homelite model 360?
I cannot find the full details for the model 360 chain saw but a typical Homelite chain saw uses the 50/1 gas/oil ratio.
1 gallon (US) 2,6 oz
1 litre 20 cc (20 ml)
If you want to download the user manual for your chain saw then please check the full model number . for example UTxxx and select this in the Homelite site.
Product Owner Manuals
Aug 21, 2014 | Homelite Garden
On a gas chain saw, do you mix the gas
there is usually a fuel/oil ratio (i think yours is 50:1) you must buy the 2 cycle oil and mix it with gas at the ratio reccommended by the manufacture. the bottle may say 6 oz per 1 gallon = 50:1 So 1 bottle of 2 cycle oil for every gallon of gas. mix them in a proper fuel can. then let the cutting begin.
Mar 17, 2011 | Homelite ZR10926 16 Chain Saw
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
Just got a homelite 33cc 14 inch chain saw, do you mix gas and oil on this chain saw?
Yes you do! The ratio is 50:1 fuel to oil. Be sure to use a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Be sure to use fresh fuel and mix the two in it's own container. Be sure to shake the container thoroughly each time just before refueling to prevent oil starvation in the engine. Don't make up more than one gallon at a time unless sawing is your business. Hope this helps!
Dec 15, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Correct mix of gas and oil for Chain Saw
The ratio is 40:1, provided this is a gasoline homelite chainsaw. Find the suitable amount to put into the gas can at a ratio of 3.2 oz per gallon. The bottles that you buy the oil in have marks on them telling you how much there is, and often times, are sized to dump into a preset amount of gas. Put the oil in the can, then put the gas in the can, cap, and shake. Always shake before dispensing.
May 30, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I have a 3300 homelite chainsaw 16'bar,what is the oil,gas ratio?
This should run well with 40:1 ratio using modern synthetic saw oils only. Always premix the fuel and oil in a can before adding to the saw, then agitate the saw to mix the old with the new. Hope this helps!
May 03, 2010 | Homelite ZR10926 16 Chain Saw
Homelite chain saw --first time user--do you mix oil and gas--two compartments--is the first compartment for bar oil
In the compartment closest to the chainsaw bar, you need to fill this with chain and bar oil. Any good name brand will work fine.
In the other compartment you need to add a mix of petrol and oil in the ratio specified for your saw. If unsure, 25:1 petrol/oil ratio should be ok.
Jul 21, 2009 | Homelite Garden
Homelite Chainsaw UT10901A Owners Manual
Hi
This is the closest I found on the net .
hope it helps .
http://www.partsmadeeasy.com/manuals/6164.pdf
All the best and good luck
Jul 19, 2009 | Homelite Garden
Need Manual
Go to jackssmallengines.com/searchdb2.cfm Click parts look up, click parts look up again, choose homelite under select OEM, click homelite, click chain saws, follow down list to model no. and click on it.
Apr 09, 2009 | Homelite Garden
Oregon Cutting Systems Chain Saw Cutting Chains, 16" Logo
212 people viewed this question
Top Oregon Cutting Systems Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you an Oregon Cutting Systems Garden Expert? Answer questions, earn points and help others
