Question about Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television
My tv has begun showing a red shadow behind the pictures as well as letters, i have gone into the converge settings to resolve but cant figure it out
    Novelist:
  • 85 Answers
Joeclaudiaag,
When the convergence will not adjust after you know you have set them correctly using your TV's convergence adjustment, your convergence board went bad. You can either repair it yourself with kits sold online (links below) but unless you know how to solder very well, opt for a repair guy. Your model will cost between $350 and $450 if you hire someone.
http://www.tvrepairkits.com/xcart/product.php?productid=20095&cat=0&page=1
http://servicemanuals.vstore.ca/product_info.php/pName/hitachi-dp-14g-43uwx10b61uwx10b-convergence-repair-kit/cName/convergence-repair-kits
http://servicemanuals.vstore.ca/product_info.php/pName/hitachi-dp15-convergence-upgrade-kit/cName/convergence-repair-kits
If you like to tinker but not dwell into the soldering world, try finding the same model for free or dirt cheap on a web site like www.craigslist.org that still works but like where a kid jumped into the screen!, and swap out the board.
Good Luck! Please rate this answer if I was able to help.
Posted on Mar 27, 2011
There is a blue shadow (especially around on screen graphics, lettering etc.) when in HD mode. I attempted to align the colors through the color convergence but the blue alignment did not work. I also...
No.This tv have a convergence problems,it dead.The tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board,must be repaired by repacling 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Picture shadow
No I am afraid you have the typical convergence problem. if you tried the adjustment, and it did not work, there are two convergence amp IC's that need to be replaced. they are on the printed circuit board, and they stand up mounted to a large metal heatsink. The IC's are black, and have white lettering on them, and statrt with STK. They will need to be unsoldered. If you have the soldering knowhow, this should not be so bad for you to do. But if you do not, play it safe and have a tech come in and replace these convergence amp IC's. Good Luck
Jun 07, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
We need to figure out how to get it off of the 3d setting we just recieved this tv from a friend of ours and we are trying to figure out how to view it without the 3d our tv is a mitsubishi big screen...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 29, 2011 | Mitsubishi WS-65907 65" Rear Projection...
The red in the picture is shadowing the rest of the picture giving it a 3d effect
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 23, 2011 | Sony KP-53HS30 53" Rear Projection...
All the lettering on my screen as well as images have a red shadow
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must have to be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Red shadow
Ur tv have a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.All these parts must be change to solved convergence problems.The shop will cost U $300-350 for parts and labors.
May 26, 2010 | Sony KP-51HW40 51" Rear Projection...
Panasonic PT47WX54J is showing a red shadow behind words and pict
you need to go to your remote, look up menu. then select "convergence"...this will give you a "crosshairs pattern to align your "guns" ...it has three red, blue, and green.....try not to move the TV around too much....its knocking them out of alignment
Oct 01, 2009 | Panasonic PT-47WX49 47" Rear Projection...
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Red shadowing
stk 392-110 ic's on convergence board are likely problem.
from rear, board is at bottom right. I usually replace all but they are marked by colour.
Jun 24, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Panasonic PT-56WX53 53" Rear Projection HDTV-Ready Television Logo
157 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
