Question about Frigidaire Kitchen Ranges
I tried to use the self-cleaning feature on our ES200-300 and it didn't work but now the stove beeps everytime we open the oven door? HELP!!!
  • Frigidaire Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Mar 27, 2011
How do I stop and open door in the self cleaning?I have a hugh mess in the oven I clean the extra stuff on the bottom what happens if it starts fire and I can not shut off and open the door.
Large spots should be cleaned BEFORE starting self clean..The self clean can not be "paused" and continued..It has to be shut down and re started..
Jul 16, 2009 | Whirlpool Accubake RF362LXTT Electric...
Stove door locked and continues to beep and flash code F9
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Mar 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleanning oven - door is lock and I can not get it to open
if you open the lid on your stove,you will probably be able to reset the
switch manually (the latch).with the lid up its located toward the front
behind the safety latch.(by no means attempt to force,bypass,or disable this
switch)this is a safety feature designed to protect you from the high temps
generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Try this, and let me know if it worked, I am trying to help someone else with the same problem, that stove is Model, 790
Mar 07, 2009 | Kenmore Ovens
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
The door on my frigidaire stove model # FEF389WJCC locked and we are unable to get it open. We werent self cleaning the oven so I'm not sure what happened. Any suggestions how to fix it? We did try...
Hello kmgtsg,
Welcome
You said, The door on my frigidaire stove model # FEF389WJCC locked and we are unable to get it open. We weren't self cleaning the oven so I'm not sure what happened. Any suggestions how to fix it? We did try turning the breaker off and that didn't help.
Did you leave the breaker off for 5 minutes or just flicked it off and on?
It may be a faulty door Latch
The door latch consist of a micro switch and solenoid. Once the door is closed and the latch handle.
But first try to deactivate the door lock
Oven Lockout
To activate the Oven Lockout feature:
1. Press and hold for 3 seconds
2. After 3 seconds a beep will sound, LOC will appear & "DOOR
LOCKED" will flash in the display. Once the oven door is locked
the "DOOR LOCKED" indicator will stop flashing.
To reactivate normal oven operation:
1. Press and hold for 3 seconds. A beep will sound. LOC will
clear. The "DOOR LOCKED" will continue to flash until the oven
door has completely unlocked
2. The oven is again fully operational.
Let me know if these procedures work for you!!
Huuum,
Please remember to leave a rating!
Oct 14, 2008 | Frigidaire Kitchen Ranges
Can't open door for self clean oven
The door won’t open until oven has cooled as a safety feature. Self clean is high temperatures.
Jan 09, 2018 | Frigidaire GLEFM385D Electric Kitchen...
Self-clean feature
hi .thanks for the question. f 3 on Frigidaire stoves, mean an open oven sensor. located in the oven top left corner, looks like a pen . replace the sensor. thanks the appliance doc
Oct 05, 2008 | Frigidaire FGF355FS Kitchen Range
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Oven Door is locked and will not open
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
Jun 06, 2008 | GE JBP70SKSS Stainless Steel Electric...
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
131 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
