Question about Maytag Dryers
No I need to know how old is this maytag dryer here is model number and s/n pye 2300 ayw and s/n 1078300zw
    Sergeant:
  • 192 Answers
October 2001
Found it at the link below.
http://www.applianceaid.com/age_maytag.html
Hope I was able to help you Ed.
Posted on Mar 27, 2011
Maytag clothes dryer Model PYE 2300 AYW will not start. All elements tested okay. pye2300 AYW won't start.
Check the door switch. It might be a small button under the edge of the door. It's possible it is stuck.
Sep 26, 2013 | Maytag Clothes Dryer Almond Timer Knob...
No heat in dryer
If you have a gas dryer then here is a tip that I wrote about that problem...
If you have an electric dryer, check out thet tip for electric dryers at the bottom of the gas dryer tip...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 28, 2010 | Maytag Dryers
How do you replace the heating element in a Maytag PYE-2300
Unplug the dryer cord.
Use a putty knife to release the 2 spring clamps holding the top lid to the front panel. They will be about 2 inches in from the right and left sides where the top meets the front.
Raise the top lid and fold it towards the rear of the dryer.
The heating element will be in the back left corner.
Remove the hi-limit thermostat on top of the element. Remove the element retaining screw and remove the element.
You should replace the hi-limit thermostat also.
Dec 14, 2009 | Maytag Dryers
Maytag Model PYE 2300 AYW Dryer will not Start
How about the controller that turns everything on? Check for power to it? Relays(if any) working?
Aug 28, 2017 | Maytag PYE2300AY Electric Dryer
Maytag pye 2300 dryer
Don't know if you still need the info on this. Found mine mounted on the housing for the heater. Also goes by 36F14 20021
May 09, 2009 | Maytag PYE2300AY Electric Dryer
PYE3360AYW
it could be a deffective cycling thermostat or high limit thermostat. check them and clean any lint built up on them or around them.
Apr 24, 2009 | Maytag PYE2300AY Electric Dryer
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
My maytag performa pye2300ayw dryer will start but will not heat up. No matter how long I leave it on, it just won't heat up. what could be the source of the problem? the model number - pye2300ayw rev - 10...
You have a thermal overload switch that may be bad. It is located under the top of the dryer. Check first the breakers. Turn them off and then back on, then check the wiring in the back of the dryer and then the element itself. It may take 30 minutes to do all of this, but it will save you a lot in the long run.
Mar 04, 2009 | Maytag Dryers
Need ohm readings for Maytag Performa Model PYE 3200AYW
Go to this site for info on your dryer type, you may find what you need there...
http://www.applianceaid.com/ww-and-mc.html
Jan 14, 2009 | Maytag PYE2300AY Electric Dryer
they are actually located under he top along hte back wall, next to the heater asy, acessable from the top of unit. here is the thermal fuse kit number LA-1053
Nov 09, 2008 | Kenmore 64902 Electric Dryer
Dryers Logo
62 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
