Question about NetGear DG814 DSL Modem Internet Gateway Router
Needs to know more about MTU size changes
I want to know more about MTU size changing. Actually I want to fragment the packets into minimium size of MTU. So I set the MTU size as 10 to 20. How come I will know that my MTU size changes are reflecting.
Thanks,
Nirmala
    Brigadier General:
  • 10,406 Answers
Changing the MTU size to any "small" value is a bad idea -- compare it to running to the corner store every time that you need to take anything (milk, ice-cube) out of your refrigerator -- the "time" to go back-and-forth to the store (or the Internet) will be excessive, and "slow" down your productivity.
Posted on May 31, 2009
How do I fix server error 8004849
This is from Microsoft:-
If you receive Server Error: 0x80048849 and/ or 0x80048820 in Windows Live Mail at home or while you're in your regular network, it may be due to the setting of the MTU (Maximum Transmission Unit) on the mail client.
If you get this synchronization error at a coffee shop, airport or a place from where you don't usually connect to the internet, we suggest synchronizing mail on your regular internet connection.
When the MTU setting on the mail client is larger than the MTU settings configured on network devices between your mail client and the mail client servers, some data packets may be lost, causing mail synchronization to fail.
Follow the steps given below to fix synchronization errors due to mismatched MTU settings:
Determine the MTU setting on your network device
Apply the MTU setting to your mail client
This is a trial and error process, and will be different for each user. You may have to repeat the procedure below a few times, before you can find out the MTU setting of your network device. Follow the steps below:
Open command prompt
Click Start ? Run ? Type cmd
In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1500
Notes:
The <Mail server address> is the IP address of the mail server that you are unable to synchronize with.
For Hotmail, 65.55.33.106 is the IP address for DeltaSync (mail.services.live.com).In this document we will be using this IP address as an example.
In the -l 1500, 1500 is the max MTU for Ethernet connections.
You may get an error like this (100% packet loss):
C:\Users\username>ping 65.55.33.106 -f -l 1500
Pinging 65.55.33.106 with 1500 bytes of data:
Packet needs to be fragmented but DF set.
Ping statistics for 65.55.33.106:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
If you received the error above, subtract 28 from the 1500 bytes of data. In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1472
If you get a 0% Packet Loss with 1472, it means the MTU setting of your configured network is 1472
Note: If you continue to receive the error described in (b) above, repeat the above steps by subtracting 28 from 1472 bytes of data. Repeat these steps until you get a message for 0% packet loss. If you were able to communicate with the mail server at an MTU size of 1424, you will receive the following:
C:\Users\username>ping 65.55.33.106 -f -l 1424
Pinging 65.55.33.106 with 1424 bytes of data:
Reply from 65.55.33.106: bytes=1424 time=230ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=196ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=162ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=163ms TTL=241
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 162ms, Maximum = 230ms, Average = 187ms
Open command prompt as administrator (you must be an admin on the computer)
netsh int ip show int
You will receive a message similar to the following. Find the connection name that you use to connect to the internet and note the Idx value
C:\Users\Username>netsh int ip show int
Idx Met MTU State Name
1 50 1472 connected Loopback Pseudo-Interface 1
11 20 1472 connected Local Area Connection
To apply the correct MTU setting on your mail client, type the following in command prompt:
netsh int ip set interface <Idx value> mtu= <MTU setting of your router> store=persistent
Press Enter
For example, if the correct MTU setting was 1424 and Idx value of your connection was 11, you will type:
netsh int ip set interface 11 mtu=1424 store=persistent
If (c ) was successful, you will receive the confirmation message "Ok"
Exit command prompt
Restart your computer
Open WL Mail and see if the issue persists.
have Windows Vista Home Premium Recently unable to send or recieve Window...
Feb 12, 2015 | Toshiba Computers & Internet
My status light just blips and i am unable to browse the internet
With some older Cable modems there may be speed negotiation problems, you will see the WAN LED on the router flashing really fast as soon as you connect the Cable Modem to it.
To fix the problem you need to turn both the modem and the router off (unplug the power cable). Then turn the modem on first. After that turn the router on. After that the two devices will autonegotiate the link correctly.
Note: If you see WAN light flashing rapidly and one of the LAN lights flashing fast as well, such behaviour is due to network traffic going in/out the router. Exessive traffic may be related to virus or trojan infection on one of the computers on your LAN.
You might try lowering the MTU value on your router. The MTU can be changed to accommodate fragmentation of packets; specially encoded packets with secured data can be too large for the current MTU and cause too much fragmentation.
Or:
Step 1 Open your browser, enter the IP address of your router (192.168.0.1) and click OK.
Step 2 Enter your username (admin) and leave the password field blank, which is the default password. Click OK to enter the web configuration page for the device.
Step 3 Click on the Home tab and click on WAN on the left side.
Step 4 The default MTU rate is 1500, to change this enter the number in the MTU field and click the Apply button to save your settings. (Start off with 1452)
Step 5 Test your ability to connect to those specific sites you're having trouble with. If changing the MTU rate to 1452 does not resolve the problem, start lowering it in increments of ten until the problem is resolved (you may need to go as fairly low depending on your DSL connection).
If you do not have this option, please upgrade your firmware at http://support.dlink.com/downloads
Nov 05, 2010 | D-Link AirPlus DI-524 Wireless Router
I'm getting twice the download speed from my Xavi 7868r router than I get from my new zyxel p660hw-d1 router. The adsl ppp led blinks green then goes to permanent orange is this an alarm? The router came...
My Zyxel cruises along at 10 megabits with no problems. If you are using PPPoE then the light will turn green as the DSL synchs up and connects, and then, after the PPP connection is made (which means that the userid and password are accepted and the device is assigned things by the connection, the light will switch to orange. It blinks when data is transmitted, so this is a NORMAL state for someone who uses PPPoE or PPPoA for their connection. For someone like me who uses ethernet encapsulation, it stays green.
Are you actually on Telefonica de Espana? One of the things I've noted on my pre-configured router is that it uses specific settings for the ATM stuff that matches what my local Telco expects, and I can't change them. I would not expect this to work with anyone else's system.
But 50% speed? Wow, first thing I'd check is my MTU. Depending on what system you have, I'd set my max MTU to about 1400 on my PC to see if that fixes anything. The issue might be that you are getting fragmenting in the connection between the ZyXel and the main system. Problem is that most MTU (Maximum Transmission Unit) sizes are set to 1500. But the PPPoE adds an extra header for the encapsulation, which leaves you with a smaller MTU on that link, around 1492 I think so 1400 is a good number. Systems handle this 2 ways, One is to set the "don't fragment" bit, which means that an ICMP message is sent back, and the sending system has to learn that and start sending smaller packets - this takes time and can effect a short speed test.
The other possibility is that the Don't Fragment bit is not set. Then the router has to actually manipulate the packets - it splits them into multiple packets, called fragments, and the fragments then make their own way through to the final receiving system. This can be slower than just telling the sender to send smaller packets, because that only has to happen once.
It might be that while the ZyXel is fast at packets it is miserable at fragmentation because it is rarely used these days - almost everyone sets "don't fragment" and transmits smaller packets.
But there is a final thing. The ZyXel might just not be seeing the link as being as fast as your Xavi did, even though it is the same link.
You can access the ZyXel via the web and it will tell you how fast it thinks the link is. Say you are paying for a 5 meg link from your phone company. The Xavi sees it as a 5 meg link, and it has no problem getting a maxiumum of about 500 kilobits through it on a download. I have two links that are rated the same. One is seen as a 11 megabit link, the other is seen at about 6500 kilobits. I have a service call in with the telco.
Now, the ZyXel, when it is first turned on, tests the line. There are a lot of subcarriers, and it checks each for noise and loss - if it decides that most of them are not usable, it will rate the line as slower. Not sure why, it could be that the circuitry is marginal, or it could be an issue with the link or the card at the telco end.
So it decides that the link is only a 2.4 megabit link.
I would attach the Xavi to the line, attach to it with web and ask it how fast it thinks the line is.
Then I'd attach the ZyXel and see if it gets the same number. If there is a big discrepancy, I'd return it to where I got it, or if it is the telco I'd report it, they can access it remotely and see what is going on,
Jan 09, 2010 | Zyxel P660HW-D1 Router
Router
You need to know how to change the MTU packet size on the XBox?
Jul 10, 2008 | Compaq (CISCO7204VXR-DC-RF) Router
Slow internet responses
MTU Means Maximum transmission unit In computer networking, the term Maximum Transmission Unit (MTU) refers to the size (in bytes) of the largest packet that a given layer of a communications protocol can pass onwards. MTU parameters usually appear in association with a communications interface (NIC, serial port, etc.). The MTU may be fixed by standards (as is the case with Ethernet) or decided at connect time (as is usually the case with point-to-point serial links). A higher MTU brings higher bandwidth efficiency. However, large packets can block up a slow interface for some time, increasing the lag for further packets. For example, a 1500 byte packet, the largest allowed by Ethernet at the network layer (and hence most of the Internet), would tie up a 14.4k modem for about one second
Feb 26, 2008 | D-Link DI 514 Wireless Router (DI-514)
I have 20mb broadband but only 300kbs download speed
I personally have never known that changing the MTU setting can speed up your connection, as the MTU is the maximum transmition units that is sent to your pc from each web site and if the MTU setting is incorrect then some web sites will not load on your explorer page, the speed at which you download the page will not make any difference.
If you are supposed to get 20MB speed then you must be on cable and not ADSL as ADSL is a max of 8MB, so i would ring up Virgin or whoever and check the speed you should really be getting.
See these details posted on the netgear site, and you'll notice there is no mention of speed:-
Details About MTU
A packet sent to a device larger than its MTU is broken into pieces. Ideally, MTU would be set to the same — large — value on all your computers, routers and switches, as well as on all the parts of the Internet that you access. But you cannot control the MTU on the Internet, and in practice the optimum MTU size on your LAN is related to your hardware, software, wireless interference, etc.
  • Tweaking MTU size may work well in one situation, but cause performance and connection problems in others.
  • When network devices with different MTU settings communicate, packets are fragmented to accommodate the one with the smallest MTU.
  • Windows XP sets MTU automatically, that is, it optimizes computer MTU for you. This Microsoft article explains resolving lack of connection to a broadband ISP using Windows XP: How-To Configure Broadband Connections Using PPPoE.
  • Once a network device fragments a packet, the data stays fragmented until arriving at the destination computer.
Setting MTU size is a process of trial-and-error: start with the maximum value of 1500, then reduce the size until the problem goes away. Using one of these values is likely to solve problems caused by MTU size:
  • 1500. The largest Ethernet packet size; it is also the default value. This is the typical setting for non-PPPoE, non-VPN connections. The default value for NETGEAR routers, adapters and switches.
  • 1492. The size PPPoE prefers.
  • 1472. Maximum size to use for pinging. (Bigger packets are fragmented.)
  • 1468. The size DHCP prefers.
  • 1460. Usable by AOL if you don't have large email attachments, etc.
  • 1430. The size VPN and PPTP prefer.
  • 1400. Maximum size for AOL DSL.
  • 576. Typical value to connect to dial-up ISPs.
Nov 22, 2007 | Microsoft Windows XP Home Edition
MTU
MTU, Partial Loss of Internet Connection, and Performance MTU (Maximum Transmission Unit) is the largest packet a network device transmits. The best MTU setting for NETGEAR equipment is often just the default value. MTU is sometimes presented as something that can be easily changed to improve performance, but in practice this may cause problems. Leave MTU unchanged unless one of these situations applies: 1. You have problems connecting to your ISP or other Internet service, and their technical support (or NETGEAR's) recommends changing MTU. For example, these services may require an MTU change: * Yahoo email * MSN * AOL's DSL service 2. You use VPN, and have severe performance problems. 3. You used a program to "optimize" MTU for performance reasons, and now you have connectivity or performance problems. * An easy solution to most problems is to change MTU to 1400. * If you are willing to experiment, gradually reduce MTU as described in "Details of MTU", below. How to Change a Computer's MTU Size Note: If you change MTU on one computer, it is likely you will want to change it on your other computers, switches, and routers, as well. Instructions for changing MTU on other NETGEAR devices is found in the Reference Manuals. The third party Dr. TCP software can be used to change the MTU setting. 1. Download it from this link, choosing the zip file or the exe file at the top of the page. 2. Run the utility. 3. In the Adapter Settings pull down, select the Ethernet driver and adapter used to connect with the network. 4. In the MTU box, type the MTU size you are trying. 5. Click in any other box, without changing the data there. 6. Click Save. 7. Click Exit. 8. Restart the computer. Details About MTU A packet sent to a device larger than its MTU is broken into pieces. Ideally, MTU would be set to the same ? large ? value on all your computers, routers and switches, as well as on all the parts of the Internet that you access. But you cannot control the MTU on the Internet, and in practice the optimum MTU size on your LAN is related to your hardware, software, wireless interference, etc. * Tweaking MTU size may work well in one situation, but cause performance and connection problems in others. * When network devices with different MTU settings communicate, packets are fragmented to accommodate the one with the smallest MTU. * Windows XP sets MTU automatically, that is, it optimizes computer MTU for you. This Microsoft article explains resolving lack of connection to a broadband ISP using Windows XP: http://www.microsoft.com/windowsxp/using/networking/learnmore/ppoe.mspx * Once a network device fragments a packet, the data stays fragmented until arriving at the destination computer. Setting MTU size is a process of trial-and-error: start with the maximum value of 1500, then reduce the size until the problem goes away. Using one of these values is likely to solve problems caused by MTU size: * 1500. The largest Ethernet packet size; it is also the default value. This is the typical setting for non-PPPoE, non-VPN connections. The default value for NETGEAR routers, adapters and switches. * 1492. The size PPPoE prefers. * 1472. Maximum size to use for pinging. (Bigger packets are fragmented.) * 1468. The size DHCP prefers. * 1460. Usable by AOL if you don't have large email attachments, etc. * 1430. The size VPN and PPTP prefer. * 1400. Maximum size for AOL DSL. * 576. Typical value to connect to dial-up ISPs.
Feb 19, 2006 | NetGear DG814 DSL Modem Internet Gateway...
Connection problems
The current firmware allows the maximum transmission unit to be changed if needed. If you are having a problem sending or receiving email, or connecting to secure sites such as eBay, banking sites, and Hotmail, we suggest lowering the MTU in increments of ten (Ex. 1492, 1482, 1472, etc). What is my MTU? - To find the proper MTU Size, you?ll have to do a special ping of the destination you?re trying to go to. A destination could be another computer, or a URL. Step 1 Click on Start and then click Run. Step 2 Windows 95, 98, and ME users type in command (Windows NT, 2000, and XP users type in cmd) and press Enter (or click OK). Step 3 Once the window opens, you?ll need to do a special ping. Use the following syntax: ping [url] [-f] [-l] [MTU value] Example: ping yahoo.com -f -l 1472 You should start at 1472 and work your way down by 10 each time. Once you get a reply, go up by 2 until you get a fragmented packet. Take that value and add 28 to the value to account for the various TCP/IP headers. For example, lets say that 1452 was the proper value, the actual MTU size would be 1480, which is the optimum for the network we?re working with (1452+28=1480). Once you find your MTU, you can now configure your router with the proper MTU size. Note: AOL DSL+ users must use MTU of 1400. To change the MTU rate follow the steps below: For the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, and DI-784: Step 1 Open your browser, enter the IP address of your router (192.168.0.1) and click OK. Step 2 Enter your username (admin) and password (blank by default). Click OK to enter the web configuration page for the device. Step 3 Click on the Home tab and go to the WAN tab. Step 4 The default MTU is 1500, to change this enter the number in the MTU field and click the Apply button to save your settings. Step 5 Test your email. If changing the MTU does not resolve the problem, continue changing the MTU in increments of ten. Note: If you have the European version of the DI-604, this procedure will not work. If you do not have an MTU option, please upgrade your firmware.
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
Connection problems
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
Connection problems
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
NetGear DG814 DSL Modem Internet Gateway Router Logo
353 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
