Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Refrigerator is running at 50 degrees and freezer at 0. I cleaned out bottom coil & changed temp to cooler but has not changed 24 hours ago. model # tfx22zpda ww . What could it be????
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 27, 2011
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I go about 'cleaning the coils' on a GE profile model - freezer is having trouble holding 0 F and I was told this would help. thanks
It is not necessary to clean the evaporator coil.
The condenser coil underneath may need cleaning.
Use a long handle bottle brush and a vacuum cleaner.
Your refrigerator freezer temp will fluctuate from minus 5 degrees to plus 18 degrees on a regular basis.
It will not be a steady temp.
Jul 24, 2010 | GE PDS22SBRLSS Bottom Freezer Refrigerator
Compressor overheated and shut down.
Pleas put setting in the middle and give it 24 hrs and check temps
freezer would be good at 0 to 10 f
I thing you have the damper door closed.
May 24, 2010 | Whirlpool GS6NBEXR Side by Side...
Defrost brings freezer temp over 100 degrees
Unit is obviously in defrost too long. Verify defrost clock operation and time setting.You may reduce the amount of minutes per cycle that defrost is actually called on for . 20 minutes should be adequate if you are defrosting more than once per 24 hrs. Defrost clock should have "X" terminal which will terminate defrost once evaporator coils reach a certain temp. It is controlled by a three wire defrost thermostat relay(clixon) attatched to the actual coil in the event this coil reaches 50 degree,the clixon triggers the "X" wire in the timer and terminates defrosting.It figures if it reaches 50 degrees,it must then be free of ice on the coils
Jul 09, 2009 | True T-23DT Bottom Freezer Refrigerator
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Mar 31, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Temp problem. freezer temp 0 deg. fresh food 46 deg.
An hour aint enough. Turn off fridge, use blow drier, thers a huge ice cube behind that sheetmetal wall back of freezer inside wall, it takes 48 hours at 75 degrees to let it do itself. Listen for inside motor, its obvious. If so, you hve a defrost problem.
Mar 12, 2009 | Refrigerators
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE 25 side by side refrigerator ice maker problem
Assuming the temp inside the freezer is at around 0 or -2 degrees, it should dump ice every ~50 minutes or so. Again, depending on temp's, an Ice Bin should fill within 24 to 48 hours. If your freezer temp is running at around 10 degrees, everything will obviously still be frozen (below 32), but the ice maker will take longer to freeze the water than it would if it were at 0 degrees. Open both doors and place the palm of your hand on the partition between the freezer and Fresh Food compartments... (where the door gaskets seat when they're closed). The temp of the partition should be about 5 or 10 degrees warmer than body temp., If it's hotter than that, you found the problem. Either the condenser coils are dirty and need a good cleaning OR your condenser fan motor (the fan in back, near the floor in the compressor area) is failed or about to fail.
Jul 29, 2007 | Maytag MSD2756G Side by Side Refrigerator
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
511 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
