Question about GE Profile JKP56 Electric Double Oven
GE double oven Model JTP56WOA2WW top oven won't heat up, fan runs, relay clicks, no heat
  • GE Master
  • 1,902 Answers
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Mar 27, 2011
Thermador oven runs but no heat
check the relay board for a bad solder connection on the underside below one of the relays. repair or replace as needed.
Sep 28, 2014 | Thermador SMW272 Electric Double Oven
What is causing my ge single wall oven with built-in microwave oven not heating, only the fan runs?
Is it the microwave or the oven that is not heating? If the microwave is not heating it is more tan likely the magnetron. If the oven is not heating it could be the element or the control board.
Sep 01, 2014 | GE JKP86 Electric Double Oven
I have a GE microwave/convection oven that the lower oven wont heat, fan comes on top microwave works but the oven wont heat
First reset your breaker, then check your wiring in the back of the oven. You may have just a wire loose.
Feb 24, 2013 | GE Profile JT965 Electric Double Oven
Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
F2 Failure Code after cleaning cycle on GE Double
f-2 is usually a runaway oven temp which most of the time means a bad oven sensor.try replacing this first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 16, 2010 | GE Ovens
Double oven, top oven run by keypad turns off
I have a double oven. The top unit works fine. The bottle unit will turn on to cook or clean. Then after a few seconds it turns itself off.
Oct 12, 2009 | GE Profile JKP56 Electric Double Oven
Top oven has an error code (f2) It happen after a cleaning
F2 - Oven Temperature Too Hot - Depending upon model, replace relay (if present) or oven temperature sensor. Make sure to check sensor harness.
Dec 09, 2008 | Jenn-Air JJW8630C Expressions Collection...
GE double oven - bottem will not heat, top oven fine
I had a similar problem. Solved mine by resetting the manual reset thermal switch. The switch for the top oven is located behind the control panal which can be removed easily by taking out three screws then lifting up an leaning out. The switch has a red reset button, just push it in till it clicks.
For safety, SWITCH THE BREAKER OFF WHILE YOU DO THIS!!!
The lower oven switch is located behind the vent grill between the two ovens.
GE should be ashamed of hiding this feature-it isn't mentioned in the manual. I discovered it on a schematic hidden behind the control panal.
Good Luck, DVS1936
Oct 05, 2008 | GE JKP45 Electric Double Oven
Open Questions:
The convection fan comes on intermittently, starts smoking then goes off. Temperature on the display doesn't move from 100F (then it did). My wife left the door closed while it was on broil last night (not sure how long), and this morning I woke up to the smell of burnt electrical and something (one of the fans...? not sure as it was far earlier than I usually get up) running that stopped when I opened the oven door and restarted when I closed it (I'm thinking it was probably running all night). While at work, I turned the breaker off, then pulled the oven out this evening. After taking some of the metal plates off, I put the power back on and turned the oven on for a 450F bake. I don't know if the little cooling fan at the top of the unit is supposed to go on when I have the top exposed and getting plenty of air; it wasn't and it also had a faint burnt electrical smell. After disconnecting then plugging the fan power connector to the circuit board the fan ran for 10-15 seconds before it started smoking and quit. I checked voltage across the fan leads and there wasn't any. I shut the oven off, tripped the breaker, and let it cool. I then tried testing the fan motor directly i.e. bypassing the oven and using a regular outlet since the motor is rated for 120V. It ran for ~1 minute, then smoked and quit. The smoke is definitely coming from the fan rather than any adjoining wires. Is this a case of the fan AND the control board going south or one contributing to the other's demise? I should add that the clock display has been dimming for a couple of years. UPDATE (2/20): I tried just baking (as opposed to convection baking) and the bottom element did come on (I'd reported earlier that it hadn't... that was because I was using convection baking and that does only heat around the fan... just my ignorance on that one). However, the temperature readout on the display did not move from 100F though it was clearly hotter than that in the oven. I then stopped the baking mode and started convection baking. This time the temperature gauge immediately went to 141F and kept climbing. Resistance at the (room temp) temperature sensor (and at the end of the wiring harness plugged into the control board was ~1100 ohms at room temp (as its supposed to be).
Feb 19, 2016 | GE Profile JKP56 Electric Double Oven
See all GE Profile JKP56 Electric Double Oven Questions
GE Profile JKP56 Electric Double Oven Logo
181 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
