Question about Radio Communications
My galaxy dx 66v when i turn it on it stays keyed all the time even without mic pluged in..........and when i turn my talkback switch on all it does is squeal.need help
    Novelist:
  • 500 Answers
Make sure the mic connector board is not touching anything inside. if it is not.. below it is a diode for the TX/RX.. replace it with 2 914 diodes and should work again.. 99% of the time..
Posted on Mar 29, 2011
Blown fuses on galaxy dx 939 after holding mike switch for less than ten seconds
try to key it down without the mic attached and see what happens.it could be in the ic or even the final so be prepared to replace them
Nov 19, 2013 | Galaxy Radios DX 939
How do i set my galaxy dx 88 hl so the talkback is on all the time
turn the talkback knob to the right and push it in to engage talkback.when you get the volume you want leave it alone .Now key the mic.You will probably hear a squeal coming from the speaker.Now turn the volume down on the talkback knob until the squeal goes away.If you run your RF gain wide open it may squeal also.
Sep 25, 2013 | Galaxy Radios DX- 88HL Base CB Radio
How can i turn the talkback down in a galaxy 66
go to www.cbtricks.com and you will find your radio listing . the side bar tells what to look at are the next window shows how to do it.
Feb 22, 2013 | Galaxy Radios DX-66V Base CB Radio
My radio squeals with echo when my amps on
adjust your talkback to just open then set your echo to where you want it. Now turn your amp on and re-adjust both the talkback and the echo . If you have a speaker nearby the radio may be feeding back through it so move it away from your radio . Now start talking with the mic and adjust your echo because you should be able to hear yourself talk through your talkback.
Dec 21, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy dx 66v off frequency ch18 is ch19 and a galaxy 33hp2 dead key but no modulation
gal 66 check the 10kHz switch. or you may have a bad cap, or crystal,.. the 33hp2 check the am regulator transistor... is bad or shorted.
Jan 22, 2011 | Galaxy Radios DX-66V Base CB Radio
I have a uniden grant and i have wired a galaxy power desk mic with rogger beep when ever i key it up it squeals was wondering is there a way to fix that
yeah your mic gain is way too high. You can either turn off talk back if you can, or turn the gain down. Depending on how loud the talk back is, your audio may suffer. If that is the case, you will not be able to run that mic. Get an RK-56 or a Skythumper mic. They are noise canceling. You will get no squeal with that mic, and it will sound awesome.
If you really want a roger beep, take it to a tech and them install one.
Oct 23, 2010 | Galaxy Radios DX-66V Base CB Radio
I KEY MIC AND SOMETIMES WON'T TRANSMIT. TAP ON
Cold solder joints are a known bugaboo with these radios......
Feb 04, 2010 | Galaxy Radios DX-66V Base CB Radio
Will not transmitt after triple 520 final kit install,will receive fine
rather than use a small linier you decided to break your radio instead . It still sounds like a cold solder point to me .
May 26, 2009 | Galaxy Radios DX-66V Base CB Radio
Galaxy dx-66 squeals on talkback
timspur, hi. First off, using the talkback with a tuned Galaxy will give you problems, so you need to use a good noise cancelling mic like a RK 56, or Astatic 636. If your running an amp, that will only amplify the problem. Here is a mod if your comfortable working on your radio, to tone down the TB volume.
Talkback can become distorted if these radios have been "peaked," and there is no cure because the talkback just amplifies what goes to the RF section. Try adding a 470k ohm resistor from junction of C155/R207 to the junction of C187/R235 on the solder side of the board. This will also give you clean talkback on SSB and FM. Try different values of resistance to get the amount of volume you want. The less the resistance the louder the talkback will be.**
Hope this was what your looking for,, I know for a fact that the Astatic mics do help tone it down.
Let us know,,, Mechanic
Mar 12, 2008 | Galaxy Radios DX-66V Base CB Radio
Lost channels in a galaxy 66v cb radio
as far as the transmit frequency changing while you have the mic keyed this is normal, the transmit frequency is a little different than the receive, as far as the lost channels go you need to check the galaxy website and check to see if thier is any fixes listed. if none is listed then you can send the tech's a e-mail and tell them your problem and they will advise you on what to do.
Aug 15, 2007 | Galaxy Radios DX-66V Base CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
